Problem someone please help!
There is a few different things I am noticing. The car is significantly slower than it should be. When I bounce off the two step(set at 6100rpms) it will do one of two things, only build 8psi ( ~ 13psi normally) or it will sound horrible and spike to 15 psi, which I believe is the engine building knock? BTW when it spikes like this the engine will die down to 500rpms and then smooth out a few seconds later. I do NOT bounce off the two step for more then 5 seconds ever.
I took it to the track and it ran about a whole second lower, as well as fell flat on its face every launch. ( The track is where I started to notice the problems. I am not beating it at all now that I know something's wrong) I normally can pull a 1.7 60', but I could only get a 1.9 best this day. I am assuming it's because I'm not building the right amount of boost so it falls on its face? I can tell when it bogs because of driver error, but this is different.
Another thing, during one pull, halfway through third I hear a LOUD pop and the car fell flat on it's face and tripped a CEL. ( was for o2 sensor and went away by itself.)
The car is no longer consistent on boost like it was. It won't hit max boost no matter what and most of the time it will be 2-3psi less then normal. The closest it got to hitting max boost was still .8psi lower then normal. My boost is set to 23.8 psi, so I could only achieve 23.0psi once.
Weird thing is the car idles fine and the turbo seems to spool normally and the car as a whole seems to run fine except when I go into WOT. When I floor it, it feels like it's stock. Regardless of the turbo hitting lower boost, I believe there is something else involved here. I also believe all of these problems are related to the same thing, but WHAT is the question. Here is what I have checked so far:
I did a boost leak test and only a tiny bit of air coming from the throttle body, so going to replace that gasket tomorrow. I did a compression test and it came back 150, 150, 150, 153 so everything there is fine. While I was there I went ahead and replaced the plugs. I cleaned my air filter and re-oiled it as well. I change my oil every 3k miles and never later. I checked all of my vaccum lines to see if there is anything that I can visually see, but nothing out of the ordinary.
I am stuck, please let me know if there is anything else I can check to try and determine the problem before I take it to a shop. If you need any more information about my car or the issues, just let me know. All my friends keep leaning toward the tune, but I refuse to believe this for two reasons. One, the tuner, CBRD, is extremely reputable and I'm inclined to believe they did an excellent job. Two, why would it start acting funny now when it's been fine for the past 6 months? Let me know what you guys think and thanks a ton in advance!
I feel so damn bad for my car...... I hope I didn't beat her too much or something! I try my best to take excellent care of it and it only has around 40k miles on it! I drive like an old lady everywhere I go and only race here and there.
http://s947.photobucket.com/albums/a...rent=edgds.jpg
http://s947.photobucket.com/albums/a...3-EGR-1.jpg%26
I checked all the vacuum lines I can see as well, is there anything else I can look for?
Thanks for the help guys!
Chad,
My buddy has the program to log a run, if I log one can I send you the data and have you review it to the tune you set? Maybe we could find something in there ? I have no idea. Let me know what it will cost and all that. Thanks.
