Vivid Racing's review Exedy stage 1 clutch and flywheel, Agency Power bushings
Vivid Racing has just installed an Exedy stage 1 clutch, Exedy lightened flywheel, Agency Power stainless steel upper clutch line, Agency Power "under hood" shifter bushings and MOTUL GEAR 300 FULL SYNTHETIC 75-90 on my 2004 RS and this is my review for these products.
Clutch, Flywheel and SS Line:
My RS is stock for now and my stock clutch, that has 81k on it, just started to slip. I decided to go with the Exedy stage 1 clutch and the lightened flywheel. After putting about 900 miles on the the clutch and flywheel, I would have to say that the combo is exactly what I expected. The clutch pedal feels VERY aggressive the first 100 miles until the clutch starts to break in. After the break in period you can really feel a difference. The pedal feels almost like stock, just a little bit heavier. Grabbing each gear is also much nicer. It is more aggressive than stock but not by much. The needle drops faster than it would with the stock flywheel but again not by much. After installing the clutch and flywheel not only did I get a better feeling clutch but I also got clutch chatter. I had a little before with the stock clutch but it is much more apparent now. It doesn't bother me at all because the evo is a noisy car. This is my second evo and I know how noisy evos can be AND me having an RS with even less noise deadening material in the car makes all the noises louder. I didn't buy a luxury car, I bought a "road going rally car"! Back to the review, I would recommend the combo if you were going to do very light mods to your evo and noises DON'T bother you then the Exedy stage 1 clutch and the lightened flywheel is for you.
Shifter bushing and Gear fluid:
I would suggest this for everyone! I don't know if it is the new fluid or the bushings but everything feels a lot tighter and smoother. After getting both of these done shifting is noticeably tighter, more precise and smoother. The first day or two is very tight but after everything is broken in it will become slightly more loose and more comfortable. I would lean more towards the bushings for the night and day difference. It is definitely worth the money.
Here are the parts and part #'s for what was installed on the car:
Exedy
Clutch: 05803
Flywheel: MF04
Agency Power
SS Clutch Line: AP-CT9A-400 (red)
Shifter Bushings: AP-CT9A-305
Thanks for reading!
Phil
Exedy
Clutch: 05803
Flywheel: MF04
Agency Power
Thanks for reading!
Phil
FX11
23
Mar 23, 2021 11:45 PM
Bignel00
Mar 27, 2015 10:48 AM
Rxracer
Northwest Region
36
Jul 28, 2010 11:27 PM
