Lots of noise after cam install
I just did a cam install and have tons of noise, sounds like marbels in the engine. Yes i bled the lifters and I had everything at TDC. Just sounds like valves are hitting!? Just curious if anyone has any ideas to what the sound might be, Im going back out to take it apart now but any suggestions would help.
Thanks Matt
Thanks Matt
Ok I have Supertech Dual valve springs with valves and retainers. Stock lifters and rockers, I had the GSC S1 cams in it prior to installing new GSC S2 cams which are in right now. Engine is not build.
What needs to line up for it to be at TDC, I want to double check
well check the cam gears for tdc, and make sure the crank and oil pump are lined up as well.. could very well be ur a tooth or more off of any of those marks... also, when u bleed lifters it says u should hold rpms at like 3k or something for a few seconds, let it idle, then repeat... I personally have never bled lifters when doing a cam install
is the install on a IX? supertechs have very high seat pressure and anytime we remove a head or install cams on them they will do this unless the MIVEC gear is primed by hand before starting. turn the car off and take the valve cover off. get someone to watch the rockers/lifters on the intake side and someone turn the crank by hand. If the clicking continues then this is the problem
Yeah I just need to know what to line up for it to be on TDC Im afraid it might be a tooth or 2 off, but want to double check. This is the second time installing cams and last time when I started it up everything was perfect, no noise and didnt have to hold at 3k and let idle. I will give this a try tho.
after you bleed the lifters they are crazy loud until they fill back up with oil. if your at TDC, and the car runs fine, let it idle for a minute or two, rev it to 3k and hold for 45 seconds then let off. let it idle for a minute, then rev to 3k and hold for 45 seconds. keep repeating until lifters are pressurized and the ticking goes away.
the mivec gear will also be very loud, but it usually goes away in 3-5 seconds.
of course don't start the car unless you know for sure it is at TDC...
it should be clicking when you turn it by hand rather loudly. did you make sure to set the MIVEC cam gear fully retarded when it was at TDC, you know how you can move it a couple degrees? You must make sure it is turned all the way back and lined up. Leave the plugs in the car so u get good compression, go back and turn the crank again(Do not do it slow like lining up timing, turn it sort of quickly) and get someone to listen on the cam gear side and watch the rockers sometimes you can see them kick back up fast like their isnt enough oil pressure in the lifters yet/
Yeah i didn't want to have running with all that noise if there was something wrong so I shut it down. But how do i know its at TDC? It's been a while since last cam install and I don't remember
take the top timing cover off and make the white marks on the cam gears line up with the lines on the valve cover. then take a flash light and look down behind the serp belt for the mark on the crank pulley to line up with the marks on the bottom timing cover. Do not be surprised if the bottom one is slightly off
Well I found out what was making the noise. I had my dad turn the engine over and noticed that the MIVEC cam was turning the it looked liked it would jump/ turn real quick and then it would make the popping noise. Not to sure why its doing this, is it bc the lifters are not filled with oil causing it to do this? Also not 100 percent sure but does the MIVEC cam stop spinning while engine is turning, seems it would just never noticed before. Just dont want to keep installing everything then taking it back apart to do it all over again
Yup, this is the prob i was describing to you. The cam gear advances timing when the car is running. A THE OTHER guys said, you can prolly let it run for a min for the cam gear to fill with oil. sometime we will get them where we have to pour oil on that side of the head and turn it by hand till the gear primes and stops clicking.
