Battery/Aternator Problem!? Dont know what to do
I didn't have the money to spend on the mini batt at the time so I moved to trunk, alreadyhad the wires running to back bc of my amp already back there. And its installed correctly just might have to check ground again and see if the location is just in a bad place.
the charging system has 3 fuses, a 100 amp fuseable link that is connected to the positive battery cable, fuse #12 in the black box under the hood, and fuse #2 in the fuse box inside the car under the dash.
Thanks everyone for the help I got it fixed if any of you read this, As stupid as this is it was the fuse I didnt bother to check. Next time I should check that find! lol
