Clutch fork stop with Competition Twin Disc??
Old Jul 27, 2010, 11:26 AM
ElectricBlueIX's Avatar
So I'm about to order the clutch fork stop from STM and I as I looked at the pictures on their site to see how it's mounted and so forth I realized I may have a problem....
I have the Competition twin and it converts the car to a push type clutch. The bracket arms that mount on the slave cylinder look like they won't allow for the clutch fork stop to be mounted. If anyone knows what I'm talking about or has used the STM fork stop with this clutch then please help me out! Thanks.
Old Jul 27, 2010, 11:31 AM
TJPhillips36's Avatar
I believe the clutch fork stop is only for Exedy Twin/Triple plate combinations that have a problem when shifting really fast with the retaining "wave" clip popping out. Which in turn means you need to remove your trans and re-install the clip, or possibly even a new clip.
Old Jul 27, 2010, 11:34 AM
My clutch works fine with normal shifting. It's the high rpm shifts where I get lockout. When I ordered the clutch they said I would need a clutch fork stop.
Old Jul 27, 2010, 11:38 AM
binky's Avatar
You don't need the clutch fork stopper with a push style clutch. You only need it with a pull style clutch.
-Bink
Old Jul 27, 2010, 11:42 AM
My clutch has a 7 1/4in hat...
Old Jul 27, 2010, 12:45 PM
raiceboi697's Avatar
when you get a push style as stated above you dont need the clutch fork stop. My tilton(push style) i had didnt need that, it engages and disengages in a different style then the normal(pull style) clutches like the exedy.
as for the lock out issues it could be a number of issues and i would suggest talking with whom ever does your work and ask them what the causes could be so that you can figure them out and fix that issue quick
Old Jul 27, 2010, 01:15 PM
wizzo 8's Avatar
Looks like you have a part for sale. You don't need it.
Old Jul 27, 2010, 05:14 PM
reactionevo8's Avatar
you dont need a clutch fork stop you need a clutch pedal stop to keep from overextending the clutch diaphragm...which cause excess wear on the TOB the diaphragm and clutch lockout issues...
Old Jul 27, 2010, 05:23 PM
evo unknown's Avatar
Call STM and ask them..they will give your great information.
STM: 585-226-8226
p.s. STM also has free shipping on all orders until the DSM shootout as I saw a post from Emery earlier.
Old Jul 28, 2010, 09:17 AM
Thanks for all the help guys! A buddy of mine has been talking to STM the last few days for me about this issue and I also talked to my mechanic. I'm sure we'll get this figured out soon. I've only had lockout a few times. Other than that the clutch has done really well and grabs really well! It's a noisy clutch but that doesn't bother me.
Old Jul 28, 2010, 09:23 AM
Is the clutch properly adjusted, also you do need a clutch pedal stop. To help from over extending the throw out bearing? Do you have one of them?
Old Jul 28, 2010, 11:48 AM
TIGERJC's Avatar
I haven't had any issues with my comp twin when it came to lockouts
Old Sep 20, 2010, 05:04 AM
outtanowhere's Avatar
competition twin.
How do you install the clutch rod from the fork to the slave cylinder? Doesn't seem to work for me.
Old Sep 20, 2010, 06:29 AM
you flipped the slave cylinder around right?
Old May 19, 2016, 09:39 AM
Lpu22rocker's Avatar
Did you ever figure out why you were getting high rpm lock out with the competition twin disk? I am currently having this issue with my competition twin disk.
Quick Reply: Clutch fork stop with Competition Twin Disc??
