Why can't you use VTA BOV valves in Evos?
Every thread states that the engine stutters and idles poorly when using an aftermarket BOV that vents to atmosphere (vta).
Why is that? I've have two other turbo cars and neither of those had this issue.
What is the way to fix it? Aftermarket ECU ala Vishnu?
they have map sensors not mas sensors (except the eclipse). You can get an AEM EMS and compensate for it but that is a tad extreme, some people have had reflashes and dont seem to have any problems
If you fit an open element air filter, you'll get some of the noise (if thats what you are after), since you are taking the air out of a 100% sealed environment.
Some cars seem to be more affected than others (not just Evo's, but Subaru's, etc as well). But the correct way is to recirc, until you convert to full MAP and ditch the MAF
I tryed VTA and If you are picky about driveablity then spend your money on a intake like the AEM. You will get two things for the price of one. Vent sound just like VTA and better topend once you start adding mods.
actually i have my hks ssbov recirc and i have weird idling now....
i really want VTA actually.. heh my recirc is loud..but i want it louder! yay it just sounds soooo badazzz... pssssssssssssshhh!
what really happens is that you are reading your air volume coming in through the mas which is before the BoV.... so when your computer corrects your fuel and then you end up VTA you end up being extremely rich and this cause stalling and extremely bad gas milage..... most 2gen dsms can;t vta with out a VPC... which takes the MAS out of the loop....
So if you can get a conputer like the AEM you will be able to remove the MAS and have no problems VTA....
hope this somewhat clarifies things
landis507
25
Mar 13, 2008 01:40 PM
RalliArtEvoVIII
65
Aug 5, 2005 08:32 PM
RalliArtEvoVIII
May 8, 2005 07:15 PM
