OEM Knock Sensor with Pistons?
Hello guys.
Do you know aftermarket pistons which works with the standart knock-sensor from evo 7-9?
I heard, most of the aftermarket pistons will make problems with the standart knock sensor, because they rattle inside the cylinder and the knocksensor would be activated.
Hello guys.
The stock knock sensor is tuned to recognize knock harmonics from the engine's accoustics. Once parts are added the accoustics change so the knock sensor looses it's tune, even with simple bolt-ons such as cams and exhaust.
Correctly fitted aftermarket forged pistons will not have an adverse effect, simply because the additional clearance is reduced when the piston comes to operating temperature and expands.
Aftermarket pistons, rods, cams exhaust, etc., will not adversely affect the frequency of detonation, and will not affect the ECU's ability to detect knock. The ECU's knock detection capability works very, very well with a built block and every popular upgrade.
X Double Dot
Jan 20, 2015 04:55 PM
Anarchy99
May 2, 2013 02:07 PM
yourSpecialisT
Dec 29, 2011 06:24 PM
YaroRS
23
Jan 28, 2010 05:38 AM
