6 speed trannies can use mobile-1 5w30???
http://www.allpar.com/fix/gear-oil.html
I've used the mopar 75w-85 trans lube before and was trying to look for an online retailer and stumbled across this link?? I dunno if I have the guts to try it but it says that mobil 1 5w30 full synthetic high mileage engine oil is almost exactly the same as the mopar fluid and can be substituted since it's gl4 like in how it's safe to use with yellow metals.
I know they will, it's always amsoil or mt 90 which I don't really care for. I either use oem, or exact equivalent. 75w85w gl4, which the mopar is at half the price. Now if this oil which is a gf4 and self proclaimed yellow metal safe synthetic is almost identical in weight, that's like a fifth if the cost of oem drag queen....imagine the savings on someone using the new 6 speed sheep trans who drags/autocrosses....nothing wrong with saving money.
I was reading some pretty well informed discussions about motor oils and the subject of 5W-30 Mobil1 came up with respect to the 30W oil not being that great at higher engine temps. The 0W-40 and the 5W-40 were prefered.
Now you'd be sailing in unchartered waters sticking 5W-30 motor oil in your manual tranny. Gear oil has to be able to withstand incredibly high shear forces.
I have to assume the friction on the gears with one of those turbo diesel trucks towing a load would far surpass our temps and there the ones trying it...I just can't find any more sites with people trying it out, I'm hoping to read of a viper or ls1 trying it out as that's how I heard of the mopar trans lube.
I wouldn't just go and use motor oil in my Evo's tranny just because one guy with a Honcho P/U said so. Consult directly with an expert. Call Shep and ask him. Consult with the AMSOIL reps on this forum. PM a guy over on LancerRegister called The Oilman.
I might just get a tranny temp gauge and log some temps. Call someone at mobil and make sure their oil is a gl4 equivalent and give it a shot monitoring temp. Whats the worst that could happen?
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
Hey, why stop at the transmission, try it in the transfer case and rear differential too. My mind reels at the convenience of going to Walmart for all my lubrication needs and bringing it all home in one jug.
Disclaimer: Use of lubricants that do not SPECIFICALLY meet that of the manufacturer's specified lubricant may void the vehicle's warranty. Use of non-OEM recommended lubricants (or lubricants which are not guaranteed to meet or exceed OEM lubricants for the specified use) is at the risk and liability of the vehicle's owner and not me. Use of the Mobil 1 product for this purpose constitutes acceptance of this disclaimer.
![Upside Down Smiley](https://www.evolutionm.net/forums/images/smilies/uppydown3d.gif)
Disclaimer: Use of lubricants that do not SPECIFICALLY meet that of the manufacturer's specified lubricant may void the vehicle's warranty. Use of non-OEM recommended lubricants (or lubricants which are not guaranteed to meet or exceed OEM lubricants for the specified use) is at the risk and liability of the vehicle's owner and not me. Use of the Mobil 1 product for this purpose constitutes acceptance of this disclaimer.![Upside Down Smiley](https://www.evolutionm.net/forums/images/smilies/uppydown3d.gif)
Well, lets say I tried M1, left it in for the recommended drain interval and nothing bad happened. What does that prove? Most parts are designed to last the life of the vehicle – say 200,000 miles. Okay, some parts fail before this due to bad design, bad workmanship or road hazard but that is the ideal. So, showing that this alternative lubricant will last 30K in the total scheme of things means nothing.
So, say I drove the entire 200K with no bad result? Is anyone interested in waiting around for this test data?
Or, the alternative, suppose I drove on this lubricant for 30K and the transmission failed. What does that prove? Maybe the transmission would have failed anyway.
The point is, unless you have the capability of doing big time testing it is all conjecture.
You can do it! 5w-30 and 75w-85 are exactly the same! It will work perfectly! This is brilliant!
No, wait. I'm wrong. Don't do it. They're not the same. It's not a good idea. But think of the money you'd save! It can't be that bad! They'll do the warrenty work and never know! Ah ah ah, they'd know. The gear set will overheat as the temps rise and they'll shatter. No they won't! They'll be fine.
This is the summary of the thread should it continue much longer.
OP, please post your results should you choose to go ahead with this idea.
![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
Nah no need, I'm ordering a temp gauge for the tranny and I'm gonna watch temps on it in different load scenarios first. Then I have to do alot of reading first before I'm even going to run the fluid in it, trust me I'm always eager to prove I'm right about something but I'm also not about to **** in my tranny to prove I can. I found a site where alot of LS1 boys are trying it out and they seem to use alot of the same fluids. Someone mentioned expansions of fluids and I wanna make sure the two fluids will act the same too, I dunno maybe a beaker setup with both fluids heated to a certain temp and the levels measured....if mobil 1 does indeed say they are yellow metal friendly I will feel alot Better about putting it my tranny (with my eye on the temp gauge) and go from there. I just don't see how a gear grinding at 7000 rpms and a piston moving at the same speed could differ so greatly in oil breakdown. As long as tranny operating temps average about 200 deg Fahrenheit, I'll keep moving ahead with this probably really stupid waste of my time project.
