Broken boost control solenoid
Was getting a random Cel P0243 (wastegate solenoid malfunction) and when I checked the solenoid had broken in half where it mounts to the gold bracket under the airbox. I have a Elec boost controller already installed and even though it bybasses the bcs, I know this still needs to be connected to not get that Cel. My question is, when the random times the cel comes on, is the ecu trying to mess with any boost or afr's to compensate and since I'm having a hard time obtaining a new one, since its pretty much to just avoid the cel, if I place maybe a 2.2k ohm resistor in place of the bcs could that possibly complete the circuit. Any help is appreciated.
Actually you can turn that CEL off by rewritting some of the code. PM me and I can point you in the right direction.
Josh
