Exedy triple-disc noise
I am just wondering how many others have the Exedy MM023HR triple disc clutch and how much noise it was making. Mine makes noise when I press in the clutch and has alot of chatter when decelerating. I expected some noise but not sure how much. Other than that, the clutch holds great and good drivability.
Marbles rolling around in the tranny, yay. I just got mine installed, it's quite grabby, have you tried to downshift too far and had it act like it's bump starting the car yet? I gotta remember it isn't an ACT. How is the engagement point on yours? How do you have it adjusted? I posted a little while back with no real feedback RE: mine is adjusted all the way out (the adjustment bolt is two threads into the clutch pedal) and it still engages just a couple inches off the floor vs my old ACT engaging the exact opposite, just a couple inches in).
My twin is adjusted all the way out as well but my disc are 1/2 their life in thickness so i figured that was the problem. Obviously not
