What's the engine Main bores size?
Nobody talks about the nominal main bores size, just the clearances.
Crank journal is 57.00mm, ACL race bearings are 1.99mm each side, oil clearance is 0,04mm. So, the main bore should be 61,02mm, right?
I bought ACL race bearings and fitted main studs, but found out that half my engine block main bores need a slight thicker bearing. I'm still figuring out wether I should line bore it or stick with OEM bearings.
Looking for opinions from the experienced engine builders.
whats the markings on your block? (there should be 5 numbers on the bottom of the block where the oil pan bolts on).
Mine was 1 2 2 2 1 (tolerances) and i had it line honed.
I'm guessing that "1" is 62.01mm, "2" is 62.02mm and "0" would be 62.00mm.
So my mains bore size would be 62.02+ mm.
With stock sized ACL bearings i was getting 0.09mm clearance.
I fitted 0.025 oversize ACL bearings, and i got 0.06-0.065mm clearance.
My crank is 56.99mm
done and done
hope that helps
My crank is 56.99mm
done and done
hope that helps
My crank is 56.99mm
done and done
hope that helps
My crank is 56.99mm
done and done
hope that helps
I´m still waiting for the mic to measure the crank. Slow sellers, grr!
Just checked everything out.
My crank is 56,985mm, each bearing is 1,990mm and the main bores are 60,990mm - with main studs fitted. So, my clearance is 0,025mm. Looks fine!
dkutej
Dec 5, 2015 08:55 AM
picco97
Nov 29, 2015 01:21 PM
extremepsi
Evo 'For Sale' Engine Internals and Drivetrain
Oct 18, 2015 12:24 AM
