creating more power with a proper external wastegate dump setup
Old Aug 13, 2010 | 01:10 PM
norcalSRTrida's Avatar
Originally Posted by 4doorstreetbike
Exactly didn't feel like arguing..for your pipe your good I think you made some good power with your red
compression is far from the only reason.
their heads outflow most any other 4cyl head by a good margin.
Old Aug 13, 2010 | 01:17 PM
MJ23FE's Avatar
Originally Posted by Evoryder
Hondas make good power thanks to high compression. They don't last too long if not built.
That has to be the most retarded thing I've ever heard.
My Evo IX which has a completely stock long block from head to toe and is making 330whp/326wtq @ ~24psi on stock turbo. You're trying to tell me (in an imaginary world) that I could swap in 10:1 pistons without changing anything else and then drop my boost down to 19 psi and make the same power? So you're saying that the much more advanced head of the Honda has nothing to do with the fact that they can make more power on lower boost?
-Jalal
Old Aug 13, 2010 | 01:29 PM
MJ23FE's Avatar
Thank you, sir.
I'd like to add that the AMS CNC Head for the 4g63 flows 277 CFM Intake. OEM K20A2 heads flow in the 290 CFM range on the intake side. Fully ported K-series heads are flowing well over 300 CFM.
About a year ago, I was Englishtown for a big drag event and Head Games happened to be there. The guys name slips my mind, but I asked him how the new 4B11 head compares to the K-series head. He told me that the 4B11 is right around where the old Honda B-series heads are. Basically, they don't come close.
This isn't about Honda being better, this is about the ignorant comments 4doorstreetbike is making.
Hondas are not a good example thus there not turbo charged from the factory so there really restricted so when you do that to them that's why they see gains when doing something like this
:facepalm:
-Jalal
Old Aug 13, 2010 | 04:50 PM
94AWDcoupe's Avatar
Originally Posted by MJ23FE
This statement makes no sense at all.
The cars in the examples above were already turbocharged but without
Honda cylinder heads shame Mitsu cylinder heads. The 4B11 has just now caught up to the B-series (the last car wearing this head came out in '01) in regards to flow. And it's no contest when you compare the 4B11 to the K-series and F-series heads (AP1/2) which have both been around for just about 10 years. Like igo4bmx said above, that's the reason they can make ridiculous power on such low boost, and take off at higher boost levels.
How much power will your car actually gain from extending the dump tube will obviously vary. But if Jeff Evans is seeing these gains from making the change, then it's real.
I wonder how cars with an OEM Air Box, or a air filter with a block off plate would be effected by this.
-Jalal
Honda heads simply were made for N/A use. They do not have have a prettier torque curve when turbocharged compared to a 4g63 which just stomps it in the spool/ torque department.
Higher velocity ports give more torque in turbocharged cars. and spool the turbo faster. The size of ports and cam duration was both made smaller on the 4b11. Its not so much they "flow" better. its the velocity that is ruling king.
Honda heads do outflow mitsu heads on a flow bench. they do make better peak power at very high rpms. but the over all power band of a 4g63 is leaps and bounds better if you know how to look at a power graph. the honda also has no AWD platform to make use of meaty torque curve so their power bands actually work well for FWD use.
Honda heads shame a mitsu head? I beg to differ. A Mitsu head would suck on N/A car. The Honda head would shame it in that case. Mitsu head are way better for their intended use.
Old Aug 13, 2010 | 05:14 PM
94AWDcoupe's Avatar
Several years back I let a local Honda guy that built 8 and 9 second hondas drive my high 9 second Mitsu. He was shocked at how much fun my car was. I think the exact quote was. "my car may be as fast or faster but holy shiat my car has no torque!" one week later he had his first AWD talon. he failed miserably at building it and stuck with hondas. But I will never forget his reaction when he drove my car. He was making around 375tq in his 9 flat car. I was making 550tq in my 10 flat car. There was no comparison of the fun factor on the street with TQ and AWD.
Old Aug 13, 2010 | 05:37 PM
MJ23FE's Avatar
We won't disagree, because neither one of us have stated anything incorrect. Everything I said was in response to what 4doorstreetbike said.
They can absolutely demonstrate what the OP is talking about.
-Jalal
Old Aug 13, 2010 | 05:50 PM
C6C6CH3vo's Avatar
I once used a redneck dump.
It's a stock O2 housing with a cut out on the WG runner with a peice welded to seal the turbine outlet and no gasket. Basically the WG flapper could be seen from engine bay. Using flexible woven carbon-graphite to channel the exhaust out the hood vent and a barriered intake to keep IAT logs no more than ambient, the system actually worked good and sounded rather interesting. The only drawback was carbon monoxide poisoning and a filthy radiator.
Anyhow, the sheet that directed fumes out the hood broke so I had to use aluminum foil as a temp fix. It worked until I spun in first hittting rev limit blasting fireballs out the dump, tiny peices of foil went everywhere out the vent and I melted my wire to the pwr steering pump.
I have the part for sale if anyone would like it.
Old Jan 4, 2011 | 09:04 PM
tundeclips's Avatar
I'm sorry for resurecting an old thread but this needed to be read again. I almost fell off my chair reading this!!!!!!
evane
Nov 11, 2014 10:48 PM
extremepsi
Mar 25, 2012 07:06 AM
Quick Time
Sep 25, 2008 07:34 PM
Gruppe-S
31
Apr 8, 2008 12:58 PM
