Car won't hold boost...
Hey guys, I just did some cams in my car and changed over to ecu controlled boost as well. I had to adjust my wastgate with the 10.5 housing i put on my Evo 8. I have made some pulls and my boost will taper from peak 22psi where it is tuned at to around 12psi now. Boost leak or something else?
Definitely the first step to take would be to do a boost leak test. If you don't have good T-Bolt clamps. Worm gear clamps are trash and i recommend upgrading to T-Bolt clamps ASAP!If you have the work gear clamps, this is most likely your problem. Also, the stock Throttle body Shaft Seals only hold up to about 12PSI, so its probably leaking out of there too. Id also recommend new Throttle Body Shaft seals if you haven't already!
GearJamminMR
Feb 14, 2015 07:01 PM
evolution253
May 16, 2009 12:27 PM
Knguyen228
Jan 3, 2008 01:48 PM
