AWD Motorsports driveshaft on the BadBish
Hi all,
Last weekend we had the shootout and I asked Mike from AWD Motorsports to bring up a driveshaft with him for my car.
I was running the DEVO shaft on the car but they are out of business and the part is no longer available. It made sense to try something even lighter and that is current to everyone.
We pulled the car on the lift and took the DEVO shaft off complete with the stock front portion and the carrier bearings that were eliminated by doing that shaft and weighed the entire assembly. Weight came in at 27.9 pounds for the entire shaft from the t-case to the rear differential.
We then weighed the new complete AWD Motorsports unit. This is a stock front shaft with an upgraded lifetime warranty u-joint connected to the aluminum rear shaft. This came in at 26.1 pounds. I'll take the 1.8 pound loss. The shaft looks great, very good quality.
The installation is a breeze, just make sure you pay attention. The two halves are indexed and marked as they are balanced. Line up the two marks and put those two halves together. After that it's a simple replacement.
We also installed the Torque Solution carrier bearing bushings while we were at it, these come with the drive shaft from AWD Motorsports.
The car, if anything, is quieter now than it was before, which I wasn't expecting with the bushings.
One more thing, after removing my complete shaft from the car I donated it to Shawna and Emery from STM for Shawna's car. (ended up trading as Emery felt bad...haha) We took her stock complete shaft off the car and weighed it. I was shocked to see the weight of the stock shaft, it was a 38.1 pounds!!
For those of you looking to shed some weight, this is a good place to do it. We will now be carrying these or you can get them from AWD Motorsports.
It's got my stamp of approval on it for sure!
Here's a shot that Mike posted of the aluminum section only
Thanks man that's what i was thinking as well but was just wondering what Dave's opinion was ![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
I told Mike@AWD that when i got the funds from the AEM that i would pick up a set of c/o's and the money is ready but just trying to decide where to spend it properly.
Which c/o's do you run by the way? PM me as i don't want to take this too far OT.
Just some random numbers I came up with while doing my own 2-piece shaft.
60mm 2mm wall 1020 tube (stock)
Moment of inertia (12" length) = 9.43 kg/m^4
Torsional Stiffness = 103kN-m/rad
Failure Torque = 4243 N-m
3" 0.125 wall aluminum tube
Moment of inertia (12" length) = 8.01E-04 kg/m^4
torsional Stiffness = 82kN-m/rad
Failure Torque = 7048 N-m
2.5" 0.083 wall 4130 Chromoly steel tube
Moment of inertia (12" length) = 9.18E-04 kg/m^4
torsional Stiffness = 100kN-m/rad
Failure Torque = 5557 N-m
Larger diameter aluminum OWNS on all aspects...
Even though the actual weight is only 6% less, that aluminum shaft has about 12% less inertia then the steel DEVO shaft.
It will also absorb more of the driveline shock on a launch or hard shift.
[QUOTE=03whitegsr;8598116]Larger diameter aluminum OWNS on all aspects...
It will also absorb more of the driveline shock on a launch or hard shift.[/QUOTE]
^+1 That is why I ordered mine
should be here any day now. Looking forward to seeing it in person.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
