HELP, keeps shutting off (video clip)
usually bad CKP will not allow car to start?
how many wires is coming out of our CKP's? i dont know if its a VRS or Hall-effect type sensor.. 2 would be VRS 3 or more will be Hall-effect or modified halleffect.
tomorrow I'm going to swap the cam sensor to see if it gets better, I was told by many experienced people that a bad crankshaft sensor is not the case because when the crankshaft sensor is broken the car does not start. in the other hand, the cam sensor mos likely the culprit will update this thread tomorrow. I'm still taking advices from any one
The throttle body shaft seal won't act like that all it does is mess with your throttle response,loss like 100 rpm of spool,and sometimes the plate will stick mine is leaking like a mother and I still made 500 whp on a uncorrected mustang.I would check the timing belt then inspect everything else while your there did you check the iac motor??
I bet you it's something stupid don't stress it will help you short it out..
