Transfer Case and RTV , Good idea or Not?
Just found out I am leaking transfer case fluid. I have spotted where the Transfer case fluid is leaking from. If you look at the pictures I am pointing directly to where the Transfer Case is leaking. My question to you all is that is it safe to use RTV to stop the oil from leaking? If so, which type of RTV would you recommend?
Pictures are on this page:
https://www.evolutionm.net/forums/ev...il-leak-2.html
Thanks,
Thanks,
