ported my first evo head!!! (before and after pics)
Old Aug 24, 2010, 02:40 AM
killingmachine's Avatar
now i just need to get the guides installed the machine work done and get it on the flow bench. this is a friends head that he wanted freshened up but i thought i would go a little further. i would classify the work done here as street strip with combo chamber work. theres not a whole lot of material removal because again he just wanted some light porting so i went ahead and blended the seats, knifed the dividers took the port entry and exit out a slight bit just enough to even them out and get rid of that taper on the intake side inlet. i also trimmed the guide bosses on the exhaust down ever so slightly and knocked the intake side all the way down (not that there was a alot there to begin with) and ported it enough to get through the casting lines ont he sides of the ports and get rid of the humps in the on the sides of the throats under all the seats. lmk what ya think..........
mike
Old Aug 24, 2010, 03:18 AM
evilempire76's Avatar
Man that looks great!
Old Aug 24, 2010, 04:35 AM
charlie.tunah's Avatar
looks really good. have any before pics of the bowls?
Old Aug 24, 2010, 04:43 AM
Tuxevo's Avatar
While I'm no porting expert, I have to say that it looks like an excelent job. How long did it take you?
Old Aug 24, 2010, 05:59 AM
mrboost05's Avatar
Nice thanks for posting your before and after shots looks so smooth in there now.
Old Aug 24, 2010, 06:07 AM
BoostINurI's Avatar
Looks super good man !
Old Aug 24, 2010, 07:04 AM
thanks guys.
yeah i like to do the before pics also to show people what a differene there is once the porting is done. this head took me about 12 hours.
mike
Old Aug 24, 2010, 07:08 AM
06MREvo's Avatar
Looks great...nice job especially for your first ported head...
Old Aug 24, 2010, 07:14 AM
oh thats not my first ported head thats my fist ported evo head, ive been doing dsm and neon stuff for years. but thank u
mike
lttldggr's Avatar
I wish I had the expertise to port my own heads.... I dont think I would ever chance screwin it up.. soem things you leave to the experts...
Old Aug 24, 2010, 09:55 AM
elhalisf's Avatar
OMG, is this my head! looks sexy .
Since i will stay with a stock frame turbo and stock size valves, i only wanted a clean up of the inside chamber, removing casting lines, and smooth out anything that will cause turbulence.
yes, it will get flow benched, but unfortunately, i did not get before numbers. however, last year, i ran 11.65@116.5 mph with the mods in my sig, 23 psi and 91/meth. the only change i have made this year is speed density, so new track times with this head will be a good comparison.
Old Aug 24, 2010, 10:10 AM
MechTech's Avatar
great job, this is def something I wanna do in the future
Old Aug 24, 2010, 10:13 AM
R/TErnie's Avatar
Nice work Mike... do you have pictures after the seats have been ground?
Old Aug 24, 2010, 10:24 AM
03whitegsr's Avatar
I could be wrong, but it looks like you may have taken a fair bit of material out from the throat of the valve seat? If so, I'd have the seat throat remachined to make sure they are still round. Just have the minimum taken out, the throat to face ratio is already pretty good stock. You get a seat with thin areas and they pull heat away from the valve funny. It can end up as a burnt valve.
Check your valve tip height after the valve job too, I have a feeling you are going to need to grind the seats pretty hard since you didn't protect them from your porting work.
Looks like you have a steady hand and a lot of patience though. Good work.
Old Aug 24, 2010, 10:30 AM
pao
pao's Avatar
excellent work
Quick Reply: ported my first evo head!!! (before and after pics)
