Is IT WORTH PORTING THE STOCK MANIFOLD AND THROTTLE BODY???
#31
Buschur Ported Stock Manifold & 65mm TB good for 900whp and 8 second passes..
World's Quickest / Fastest Stock Ecu - 8.99@163mph
World's Quickest / Fastest Drag Radial Evo 8/9- 9.05@160mph
World's Quickest / Fastest Mivec Evo - 8.99@163mph
World's Quickest Stock Frame FP Black - 9.33@146mph
#32
Can you define a "real" manifold? lol The answer is simple, if you are looking for the absolute most peak horsepower, go with a larger plenum like the Magnus v5. If you're looking to increase performance across the board and improve spool characteristics there is no better option than a ported stock manifold, and in my opinion no better option that our Rev3 ![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
#33
Hi Guys,
currently im rebuilding my Evo 5 engine and i just wonder can i get extra torque & hp if i just change to a slightly bigger T/B (70mm) while maintaining my stock standard intake?
My set-up :
1) Walbro 255
2) Tomei FPR
3) 600mm x 300mm x 75mm IC with 2.5" IC piping around.
4) GSC S2 Camshaft
5) Used 85.5mm JE Pistons
6) Used BC I-Beam rods
7) PFC Ecu
8) Stock 560cc Injectors
9) Stock TD05HR 16G turbo
Can my 560cc injectors able to coupe?
Lastly, will it be very lag once i changed to a 70mm T/B?
Thanks
My set-up :
1) Walbro 255
2) Tomei FPR
4) GSC S2 Camshaft
7) PFC Ecu
Thanks
#35
Chris...I am having some work done to my exhaust and hot side that will be done by you guys...I considered doing a ported intake manifold and tb...however I am running a stock 9 turbo and I don't know of the real potential gains of your units on a stock turbo...do you have any data comparing a stock intake Manifold to your ported unit rev2 and rev3? On a stock turbo? I could see the benefits on a larger turbo but how about stock...? Thanks...I need the hot side and exhaust Manifold fast...APM will be contacting you guys...
#37
We did some testing of the Rev3 with a stock turbo, a summary of the results can be found here sir.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
#39
Hi Guys,
come back to my question, can i get extra torque & hp if i just change to a slightly bigger T/B (70mm) while maintaining my stock standard intake manifold?
Lastly,if i used a bigger T/B will it also cause more lag?
Thanks
Thanks
#40
No, if you go to a bigger TB then you'll have a step at your IM flange. You'd need to at least port that to match the larger TB opening.
Also, I don't think the TB is the main restriction here, the IM porting is where its at and that's what I'd put my money towards (Ported stock, not SMIM)
#42
#43
Not for nothing but don;t try to compare a stock manifold to a di or a v5 ..If im paying that price im gonna put a stacked manifold on my car not a ported stocker.
#44
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
#45
