2.0L 4G63 or 2.4L 4g64
so far from what i know and see the lr version can only rev higher. So far you you are not going to make more power then a std2.4 im probaly set my revs to either 7800 or 8000. Remeber there is a nice price difference in the two 3200 to 5800 for those revs broham you can build a 2.4 cheaper
I think the LR2.4 is also less vibey actually. If you have standard mounts and not something thats really stiff in the car (I prefer stock actually) there is definitely something the LR improves geometry wise that decreases vibration.
Our standard 2.4 to LR2.4 is actually 4600 to 5400. Difference is of course the rods, custom pistons vs off the shelf, and block clearancing. It is complete also, just add cylinder head.
If the rx-7 is reving to 9+ every gear execpt the gear it traps in which is still in the 8-8.5k range iirc. And it has been doing this for over a year besides the head gasket problems but thats because its making over 1000whp and the head is a evo6. Whats the point of the LR2.4l? I see aaron said it doesnt vibrate as much but performance wise?
An ER LR 2.4 is about 2K less than an AMS 2.3RR. It also uses standard parts that are less expensive to replace if something bad would happen. Standard crank is one thing. The pistons are already made just vary dish on a std stroker piston and your there. rods are usually not damaged during most failures of built motors and they can be resized so thats a good investment. Also the ER shorty is complete, just bolt on whatever head and rock. I also dont like that AMS uses the turned down balance shafts.
I think its funny about the 2.4. This reminds me of late 90s early 2000s when the DSMers started with 2.4s. These have been popular for a long time, just not as popular with the Evo community.
LR 2.4 does a have a piston that is 40g lighter and can be carved down further if wanted. A standard rod 2.4 piston is kind of portly, especially at 9k.
Aaron
Aaron
