Gum Out Flex-Fuel Injector Cleaner
One of the downsides to running E85 is that it clogs injectors. One of the locals here found this product on the internet. Hopefully it will work better than current injector cleaners on the market. I havent tried it yet but plan on getting some this week and giving it a whirl. Anything has got to beat taking out the injectors and cleaning them by hand. Here is the link to the website
http://www.gumout.com/ourProducts/fl...VehicleFIC.asp
Who has it in stock?? I have looked everywhere here in AZ.
Lucas also has one, they emailed me saying it will be out next month.
http://www.lucasoil.com/products/dis...show&headTitle= - Safeguard™ Ethanol Fuel Conditioner & Stabilizer
Im gonna hit some auto part store on the way home and I will check back in and let everyone know what I found out. Lucas is also local here in Indiana. They have a warehouse about 45 minutes from me.
Ok so I went to some of the local auto part stores in the area only find out that no one has either product yet. Hopefully stores will start selling this stuff soon. until then
One of the downsides to running E85 is that it clogs injectors. One of the locals here found this product on the internet. Hopefully it will work better than current injector cleaners on the market market...http://www.gumout.com/ourProducts/fl...VehicleFIC.asp
Xylene is a powerful solvent that is the main active ingredient in the more expensive brand-name injector cleaners.
Is your car setup with dual maps(E85/pump gas)? If it is then you could periodically run a couple of tankfuls of pump gas with a gallon of xylene(xylol) mixed into each tankful of pump gas.
My car has been full time on e85 for 2 years now, and I've finally noticed a bit of goo buildup on the injectors. Last weekend I pulled the injectors and cleaned them by running some pump 92 through them using a 12v battery and jumpers.
I'm hoping that this gumout stuff will do the trick if I run a bottle through every month ot two.
John-
I really need to start using something like this (if it works). My car hasn't seen a drop of pump gas in probably over 2 years. Last time I pulled out my injectors there was a lot of that weird gooey **** on the tips of my injectors.
Unfortunately It isn't 'just' the injectors, that gunk sticks to valves and intake ports as well! e85 compatible stuff is kind of hard to find, This is the first time I've ever found it on the shelf in any of the local Auto Parts stores.
To bad I manually cleaned the injectors before I found this, so it will be awhile before I will be able to report back with results.
John-
