Changing up my fuel system a bit
So, for those of you who don't know my fuel system in Lana, it is a 4 gallon Summit fuel cell with 2 -8 lines coming off of it. They go through pre-pump filters then Y into a -12 line, which feeds my FueLab Prodigy 41402 pump. The pump then feeds a -10 line to a post-pump filter, up to my rail, which has 4 1600cc Precision injectors, and then back via the return regulator and -8 AN line to my cell again.
I was having some intermittent fuel pump issues where it would not prime sometimes, so while the pump is being replaced, we are going to switch up the setup a little bit. Emery had a great idea to put the pump under the car, so that it is below the fuel level. Both Weldon and FueLab say that you can have the pump above the fuel level, but it is one more potential problem for losing prime in the fuel system.
The new setup will have one pre-pump filter, instead of 2, and then eliminate the Y fitting and some extra weight. Directly after the filter, will be the pump under and behind the fuel cell, under the car. This will not only keep a constant supply of fuel to the pump at all times, but it will also keep the pump much cooler. The pump flows WAY more fuel than a Walbro 255 pump, so it actually heats up the fuel pretty quickly. Being in the trunk, the FueLab pump wasn't getting any air flow, and while it was not burning hot to the touch, it did warm up quite a bit.
This new setup should be lighter, cooler, and easier to work with. If all goes to plan, it will be all ready for the Letchworth picnic this coming weekend :tup:
-mark
-mark
Finished everything up on the fuel system today up at the shop. Eliminated about 5 fittings, a filter, a few brackets, and re-did the system so that the pre-pump filter and the pump are always below the fuel line. Here's a shot from under the car, muscle car style fuel
Much better!
--mark
Much better!
--mark
--mark
TrinaBabe
23
Feb 11, 2020 04:56 PM
David Buschur
61
Jul 28, 2008 07:20 PM
David Buschur
74
Jan 17, 2007 07:09 AM
Speed Element
Dec 14, 2006 04:04 PM
