OEM vs MR Gasket MG-7235 exhaust manifold gasket
Old Sep 21, 2010, 10:16 PM
ryukinevo's Avatar
I have a 2003 evo 8 and I am upgrading to a GT35R setup. I do not want to reuse the OEM gasket with 55k miles on it over $20.
I finally verified that the Mr Gasket does work with the evo from the stmtuning website (I have not called them about it yet).
Mr Gasket is solid copper and OEM is a 4 ply copper gasket: Which gasket is the best exhaust manifold gasket?
Any opinions or ideas is appreciated!
Thank you
Old Sep 22, 2010, 02:41 AM
bbyevo8u's Avatar
i would say use the oem gasket
Old Sep 22, 2010, 12:45 PM
Evotech8's Avatar
I'd just throw in a fresh new oem gasket and be done.
i never heard anyone on evom.net with oem ex mani gasket failure yet?
Old Sep 22, 2010, 02:47 PM
SmurfZilla's Avatar
OEM.
The OEM head gasket is really good as well.
Old Sep 22, 2010, 04:02 PM
Boosted Tuning's Avatar
Oem.
Old Sep 22, 2010, 07:30 PM
nightwalker's Avatar
I have the Mr Gasket copper gasket. It's a piece of ****. It was hard to get it to stop leaking. I also had to open up the holes on the end because the Evo studs on the ends are bigger.
When I replace my turbo or exhaust manifold I'm installing a new OEM gasket.
Old Sep 23, 2010, 07:29 AM
ryukinevo's Avatar
Your bad experience helps prevent someone else from having a bad experience.
How long ago did you purchase this gasket? I just want to know if Mr Gasket might have revised it since you purchased it?
It could be that it was not specifically made for the evo since Mr Gasket does not have a evo part # for this gasket.
Old Sep 23, 2010, 06:27 PM
I bought mine last year. They haven't re-designed it. It's actually a DSM gasket re-tagged as an Evo gasket. I don't think they plan to do anything about it.
Old Sep 23, 2010, 07:16 PM
wshihdnevo's Avatar
I would use the OEM gasket for sure! I usually reuse them quite a few times before I replace them, but I would definitely replace the original stock one.
Old Sep 25, 2010, 11:25 AM
SeansEvoAte's Avatar
I usually stick to OEM gaskets wherever possible. They have been properly designed and tested. The aftermarket parts may have been as well but you know the OEM one has.
Evo47
Mar 10, 2016 10:27 AM
beasters
Aug 1, 2014 11:17 AM
erald01
16
Dec 30, 2010 09:16 PM
17579EVO9MR
13
Oct 26, 2010 12:53 PM
Quick Reply: OEM vs MR Gasket MG-7235 exhaust manifold gasket
