engine sputters
engine sputters
i need help guys my car sputter when i stomp on it . i changed the spark plugs and made sure the everything is up to par but it still sputters around 4500 rpms when i stomp on it can someone help????????????
gap is .28 and i have tbe and intake and thats about it guys i just bought the car two weeks ago and it has been sitting for about a years or more. i started to use shell gas this week .
sounds trigger related?? check to see if you have any metal debris on the crank position sensor, or bent teeth or rust.... could be a loose connection or bad sensor too. Had the problem on mine and it was breaking up around 3500.
I had this same problem for months. Tryed new plugs gapping/ re-gapping etc. Had the car tuned last weekend and the tuner said i needed an upgraded COP kit. Sure enough, no more stumbling in every gear when "getting on it" usually by 5000rpm's. Anyway, might want to check it out.
2006GSR
Aug 20, 2016 09:22 PM
