TS T4 1.06a/r HTA3586
Old Oct 8, 2010, 04:23 AM
  #106
dieselmd's Avatar
Originally Posted by davidbuschur
Dieselmd, Matts car had a GT40 on it, then a GT42 and now an HTA86, I believe all of those we on the same header. Our black car had T3's, T4 single and twin scroll and quite a few really good turbo tests done on it. We must have got something right on that car, it's held the mph record now for 4 years, just throwing that out there.
With all the arguing lately I'll avoid posting dyno sheets here.
No worries.
Old Dec 25, 2010, 12:56 PM
  #107
JohnBradley's Avatar
Originally Posted by Philthy748
Dyno #'s aside, @ 21psi on straight pump gas ~560whp on Jeff Evans Dynapack, my car trapped over 130mph... 27psi on straight pump gas it made 640whp - that's never going to happen on a 3586.
Not trying to restart a shezzlestorm, but when I went to the dyno the other day and put down 648whp on straight pump, I doublechecked 21 and 23psi. I was at 555 at 21psi and 588 at 23psi still. Seems that Jeff's dyno (least on that day) reads very close to our DJ.
Old Dec 25, 2010, 03:34 PM
  #108
Philthy748's Avatar
Seems pretty much spot on - Jeffs dyno has always been very close to DJ #'s... Every once in a while a Hater will come out and claim his dyno reads very high, but with trap speeds to back it up, they are silenced...
Old Dec 25, 2010, 07:06 PM
  #109
Aby@MIL.SPEC's Avatar
Having 500 ft lbs at 3000'ish rpm and running 9.5's should be proof enough of that.
That would be better than sliced bread!
if you have that recipe, that would be called "having your cake & eating it too"
Merry Christmas to all, especially those fighting for our country
Old Dec 25, 2010, 08:11 PM
  #110
BLKCarbonEVO's Avatar
Merry Christmas to you too Aby. Also to the rest of my fellow military guys/gals that couldn't be home for the holidays.
Mikey
Old Dec 25, 2010, 08:28 PM
  #111
BiFfMaN's Avatar
They actually served a good meal for us at Kandahar AB
Old Dec 26, 2010, 10:23 AM
  #112
BURNALL_4's Avatar
Is say go with a t3 HTA 3586 .82 that hotside with your bottom end will spool like a mahcine. And will have no issues making your power goal.
Old Mar 15, 2015, 07:24 AM
  #113
sssr20det510's Avatar
I know this is an old thread but has ATP fixed there casting or is there a better twin scroll housing to use? Looking at doing a hta3582r with a t4 twin scroll.
Old Mar 15, 2015, 07:50 AM
  #114
Grimgrak's Avatar
Funny i just went with a t3 ts 1.01 gt30 NI resist. Which is the newer material and costs double what the old one did.
Old Mar 15, 2015, 07:01 PM
  #115
240Z TwinTurbo's Avatar
I was running the 1.01a/r v-band TS turbine housing from Garrett and it has equivalent flow to a 1.01 a/r open scroll. This new sizing strategy likely applies to the T3 TS units as well. I worked for Honeywell so I had conversations directly with the engineers and for the vband stuff a TS a/r has equivalent flow to OS a/r.
Old Mar 21, 2015, 11:19 AM
  #116
Grimgrak's Avatar
So I shouldn't expect it to flow like a .70? Ugh then I may have gone way too big...
Old Mar 21, 2015, 11:21 AM
  #117
Ted B's Avatar
The way TS housings function, the large side of the picture is far more forgiving than the small side.
STIbyebye
Mar 29, 2016 08:42 AM
tsi20gawd
Mar 5, 2016 07:40 PM
rsx06
Nov 11, 2015 07:29 PM
ETS Michael
140
Sep 27, 2010 07:05 PM
MagicManRed
50
Jun 21, 2010 07:59 AM
Quick Reply: TS T4 1.06a/r HTA3586
