TS T4 1.06a/r HTA3586
Old Sep 29, 2010, 02:47 PM
BLKCarbonEVO's Avatar
I was wondering is anyone has a dyno of a TS T4 1.06 HTA3586?
I'm sure someone does and I'm not sure that i have personally seen one. I am thinking of upgrading my turbo in the next couple of months. My end goal is 700-750hp daily with the best spool possible but the turbo still has to make power at 8500 on my LR2.4.
Mikey
Old Sep 29, 2010, 03:00 PM
38six's Avatar
Search for evo dave set up.
Old Sep 30, 2010, 03:38 AM
hokiruu's Avatar
Ivey tuned a similar setup maybe 1.5 years ago and started a thread, maybe you can find it. Ted B could surely advise in volumes on the matter.
Old Sep 30, 2010, 04:23 AM
[I.R.A.]_FBi's Avatar
think freddy302 had a setup like that iirc
Old Sep 30, 2010, 06:19 AM
Philthy748's Avatar
Is your goal 700-750hp or 700-750whp..? If it's whp, than look to the 4088R. I make 730whp at only 32psi...
Old Sep 30, 2010, 03:25 PM
750whp. What is your powerband like and does it hold power all the way to 8500k+ I want something that spools fairly fast too. I think I can make 700whp on a TS 3586 and have better spool than 4088.
Mikey
Old Sep 30, 2010, 03:45 PM
Philthy748's Avatar
Mikey
I doubt 750whp is at all possible on a 3586, unless it's on a very high reading dyno...
Here's some info on my build up https://www.evolutionm.net/forums/ev...croll-40r.html
Dyno #'s aside, @ 21psi on straight pump gas ~560whp on Jeff Evans Dynapack, my car trapped over 130mph... 27psi on straight pump gas it made 640whp - that's never going to happen on a 3586.
mxguy1286's Avatar
https://www.evolutionm.net/forums/ev...ta-3586-a.html
596 on pump at 30 psi
Old Sep 30, 2010, 05:17 PM
What does the Dynapack read like? A DJ?
I would like to know if your car pulls all the way to 8500 with the 4088? The 4088 may be a bit lazy, for me!
Mikey
Old Sep 30, 2010, 05:20 PM
Teal2nnr's Avatar
Mikey
It'll pull to 8500.....but the powerband will be similar to a 1000hp supra lol.....idunno 3586 is were i draw the line...thats a big ****ing Turbo
Old Sep 30, 2010, 05:21 PM
mxguy1286's Avatar
"Evans" dyno reads high from everyone I know that was tuned there and ran at the track. Just letting you know what I have found. Not sure what a dyna pack to dyno jet compare's like.
Old Sep 30, 2010, 05:29 PM
scorke's Avatar
750 whp is doable on a 3586.
Scorke
Old Sep 30, 2010, 05:54 PM
Philthy748's Avatar
my car pulls to 8500rpms and makes power there - I've had several cars tuned by Jeff over the years and his dyno reads like a DJ - don't listen to hear say, I've got first hand experience. Like I said, 21psi ~560whp on his dyno yielded +130mph trap speed.
I've race a couple guys on 35r's that 'claimed' they were making over 700whp - it wasn't even close - I pulled bus lengths on them... I don't believe that the TS 3586 has 750whp in it, unless on a moon dyno...
My car (2.3 liter) on the TS 4088R makes 200whp @ ~4100rpms - if you're looking for better boost threshold then go with the TS 3586 but don't expect 750whp.
Old Sep 30, 2010, 06:54 PM
n2oiroc's Avatar
i dont see how the 3586r would make more power. smaller compressor wheel, smaller turbine wheel and a substantially smaller turbine housing. not to mention the 4088r has a much more robust center/bearing section in it so it will be more durable.
I think the TS 4088 would be the best turbo for me to have 750whp at 8500 and not be crazy laggy! I think I'm going to talk to Garrett about the GTX upgrade. It will make 10% more power than the std 4088 and will spool faster. I would be willing to bet that it would only spool 300-400rpm slower than a TS 3586 but make 100-150hp more! New new GTX is similar to an HTA turbo so is like have a HTA4088... I wish FP made one, I'll talk with Robert and see what he has to say.
Mikey
Quick Reply: TS T4 1.06a/r HTA3586
