Dead lifter? (vid inside)
Old Jan 17, 2011, 01:07 AM
  #61
crckheadjed's Avatar
ahh back from the dead. And holy slacking on my part. between lack of time and lack of space in the garage to work on it. (2 other car restorations in progress) At this point i will just try and do this in the home garage and bring what ever tools i need back and forth...yay...not so much. But i might as well while it is still winter and dont mind the down time.
Old Feb 19, 2011, 12:30 PM
  #62
Ronnie Size's Avatar
Update on this thread...
I swapped my mivec cam gear, pulled the intake cam and checked the valve train...nothing looked aloof or askew.
Put it all back together, torqued everything down and then cranked it for a long while to build up pressure. Started it with no accessory belt on (to eliminate power steering, alternator, a/c, etc).
Noise is still there.
Now eliminated:
mivec cam gear
power steering pump
a/c pump
alternator
water pump
Old Feb 19, 2011, 04:59 PM
  #63
barneyb's Avatar
When the engine work was done, was anything done to the head? After all you have checked and done I'm thinking maybe a sticky valve or tight valve guide.
Old May 2, 2011, 08:56 PM
  #64
evilution09's Avatar
I am courious to see the end results on your noise quest. I have a similar noise after new piston and rod swap plus new 272 Kelford cams.
Old May 2, 2011, 09:09 PM
  #65
RSMike's Avatar
i am having a similar (or maybe the same) problem.
Here is my noise
http://www.youtube.com/watch?v=-XYrQNv6pKk
https://www.evolutionm.net/forums/ev...lap-video.html
more discussion here too
https://www.evolutionm.net/forums/ev...-question.html
My sound is only happening on "combustion" though. when it rev's back down there is no sound.
I'm super confused
As discussed here, it sounds like it's coming from the intake side of the valve cover.
Old May 2, 2011, 09:35 PM
  #66
My final noise determination is piston slap/bad rings. A lot of play in the cylinder movement with the head off and scores on the walls up/down. Bought a new long block.
The thread starter's problem ended up being really low compression on 1 cylinder, also related to rings I believe.
Old May 2, 2011, 09:37 PM
  #67
RSMike's Avatar
i guess i'll find out if mine is piston/ring related soon enough.
Engine is coming out as we speak
Old Jun 17, 2011, 10:39 AM
  #68
Finally
Old Jun 22, 2011, 04:28 PM
  #69
Lifter
Old Jun 22, 2011, 04:30 PM
  #70
tscompusa2's Avatar
Originally Posted by crckheadjed
Piston was pulled... No retaining clip was installed on that side of the piston. Engine builder forgot it. Wont say what shop as of yet until all is dealt with and fixed.
LOL. that is ridiculous
Old Jun 22, 2011, 04:31 PM
  #71
RSMike's Avatar
I'm glad you've found the problem, and the engine shop has claimed liability.
At least you didn't destroy the whole engine!
Good Luck with getting it all together.
I'm going through similar problems with my engine, and i know how you feel! It's not fun!
Cheers, Mike
Old Jun 23, 2011, 06:57 PM
  #72
Thanks
Old Jun 25, 2011, 01:22 PM
  #73
turbophile's Avatar
Hey guys, I have had similar issues with my 9 as of rescent. It all started when doing a 6th gear pull to around 250Kmh during a recent road trip (silly I know, but it was a very important pass in mountains ). It felt like I had hit the rev limiter, then I looked in the rear view mirror and saw a bit of white smoke. Car ran fine for another 300-400 miles afterward until I arrived to a nearby city where I began to hear a ticking noise. It progressively got worse from there.
I took it to a nearby shop, where we drained oil, ran sea-foam engine cleaner through and put in some new heavier oil. Ticking was less audible at this point but still present.
The next day I did a full throttle pull in 2nd and 3rd gears and my car just died, I lost throttle response,and again I saw some white smoke from exhaust. I coasted to a stop and car didn't start afterwards and it sounds like one of the cylinders is down on compression when I'm trying to turn it over.
Needless to say I left the car and flew back.It should arrive next week and I with my local shop mech can tear into it to have a look.
Has anyone's ticking noise progressed so far as to car not running??
Thanks
Old Jun 25, 2011, 01:35 PM
  #74
BigT's Avatar
Same thing happened to my old 6bolt DSM motor. I had 480 miles on it when it started making a funny noise very similar to whats going on in this thread. Pulled the motor apart and one of the clips in the piston let loose and started tapping against my cylinder wall. I won't name the shop that built it, I will say they are in PA.
Old Jun 26, 2011, 02:09 PM
  #75
Thanks
Sounds like a spun rod bearing, blown motor.
Std Seven
Dec 21, 2014 09:29 PM
evoxsi
140
Jun 16, 2013 01:02 AM
My03evo
43
Oct 26, 2012 10:31 PM
BaumBizzle
Mar 28, 2011 12:56 PM
evoate ya
30
Dec 23, 2008 09:14 AM
Quick Reply: Dead lifter? (vid inside)
