What a broken 6 speed looks like..
#61
Im just curious to the "why" this happend. If the vehicles were bone stock, and this happend? You can't blame torque load for the damage. So it seems its just defective peices. Who makes this 6 speed anyway? If its made in China Im going to be pissed!
#62
At the end you find how broking@4th occures (click youtube, then you find it easy)
http://www.youtube.com/watch?v=g_1ZjIJTg20
I didn't change gear there, but probably 585hp and 6speed isn't very good choise.
Does sheppard send 6 speed inside out, whole gear box weights too much to send overseas?
#63
Here it what it looks, 4th gear gears are toothless, it seem's that to get from US new 6 speed gear box is quite hard and expensive, so I need to go with 5 speed, what somebody says is stronger
![](http://wirx.ee/pildid/main.php?g2_view=core.DownloadItem&g2_itemId=106942&g2_serialNumber=1)
![](http://wirx.ee/pildid/main.php?g2_view=core.DownloadItem&g2_itemId=106938&g2_serialNumber=1)
![](http://wirx.ee/pildid/main.php?g2_view=core.DownloadItem&g2_itemId=106940&g2_serialNumber=1)
#64
im new to the evo forum... ive been searching and searching and i would like to know if this would happen if a MR 6spd is stock or maybe a little bolt on, would the transmission go bad or anything because im planning to buy a MR soon and i dont plan on tracking it or anything like that but maybe occassionally push it to the limit... stock wise, would my transmission go out? because i read on forums and im not sure if this applies to people who have stock or modded evo 9 MR... but it would make sense that Heavily mod MR would have this problem vs the stock or mild bolt on? can anyone help me or PM me some ideas so that i can have a piece of mind before buying this MR i have in mind... thanks in advance
#65
#66
i havent got a solid answer just yet, all i know is people who have MR 6speed either abused it such as put a lot of power into it, track race it, launch it, drag racing it like crazy... As for me im not going in that direction and leaving it stock to light bolt ons... Will i be fine in the long run, running stock/light bolt-ons?
#67
That said, the 6-speed tends to have a notchy 1-2 shift. I can imagine that some people might not have the patience to wait to let the gear shift lever fall into 2nd gear, and this could damage to the synchros. So if you're out test driving, a notchy 1-2 should be expected (especially in colder weather), but if it grinds badly, then that would be a sign of issues.
#70
I officially have over 140,000 miles on my OEM 6 speed. I have been pushing 300+whp (GST Mustang Dyno) for awhile. Still shifts pretty darn good. The Castrol Syntorq LT I have in my car eliminates the notchy 1-2 shift. Also have heard good things about the new 75W-85 from Redline.
Do plan on upgrading to the Shep 6 speed though when I do my 2.3 + FP Red build. I don't want to have to tune out the torque hit
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
#71
Do plan on upgrading to the Shep 6 speed though when I do my 2.3 + FP Red build. I don't want to have to tune out the torque hit![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
#72
Warrtalon who drag raced frequently and was a very active member on EvoM had over 130 quarter miles passes on MR with bolt-ons and pump gas. Killing it out on mountain roads seems unlikely because presumably the driving style isn't on the edge of sanity, and there are probably very few instances were the car could be opened up in 4th gear. The only way you could kill the 6-speed with bolt-ons and pump gas is if you regularly did 20 min+ sessions out on a (Kcircuit) track that has a straight long enough to use 4th gear. And even then, there are lots of people who are doing this without destruction.
As for the notchy 1-2, I'll check it out and see wassup with it.. The car I'm buying has 45k miles on it and the owner seems mature and doesn't look like he drove it hard... Anyways is there anything I should be aware of for the 6speed beside transmission before I make this purchase?
kikiturbo
Jan 1, 2015 01:42 PM
kikiturbo
Feb 25, 2014 03:03 AM
