Tomei arms m7960
Old May 2, 2014, 03:24 PM
  #46
yungchian.chen's Avatar
I bought new set from yahoo auction japan. 183000yen + shipping RM300++
Old May 2, 2014, 10:00 PM
  #47
TJung's Avatar
Originally Posted by superkizuna
You guys the turbo spools fast. You have to open up everything before the arms. Upgrade Intake, uicp, licp and o2. Mine rips through first, second, and third. It pulls like crazy. The spool is about 500 rpm later but with a proper launch its negligible.
Can You put picture of Yours engine bay? What intake do You have?
Old May 3, 2014, 03:25 AM
  #48
pangyau's Avatar
yungchian.chen,
The price seems reasonable but how you deal with the transport arrangement and taxation?
Do mind to share the link etc... hope to get direction on this.
Old May 3, 2014, 06:29 AM
  #49
Got friend at japan who import used parts from japan. He help me buy the turbine and transport back to malaysia.
Old May 3, 2014, 06:40 AM
  #50
This my engine bay
Old May 4, 2014, 01:54 AM
  #51
foxbat's Avatar
Originally Posted by yungchian.chen
This my engine bay
What kind of FMIC do you have?
Old May 4, 2014, 03:28 AM
  #52
pangyau's Avatar
yungchian.chen,
Lucky you... wish to have a contact to help me on this.
Getting the same unit as yours.
Old May 4, 2014, 05:33 AM
  #53
300mm x 600mm intercooler with custom intercooler piping.
Old May 4, 2014, 05:47 AM
  #54
My engine spec now:
Fully stock engine, only change greddy 260° easycam
Hks GT2 7460r Kai turbine
Monster sport airbox with k&n filter
Custom big intercooler and 3inches intercooler piping
Hks exhaust manifold, downpipe and silent high power exhuast
Stock injector with walbro 255l/h fuel pump
Ron95 target boost 1.5bar. Don't know can get how many whp??
Old May 4, 2014, 08:32 AM
  #55
Carbonlution's Avatar
Originally Posted by pangyau
Carbonlution,
What version of your TOMEI ARMS turbo? With the Blue revised actuator?
TJung,
How much power do you able to make with this turbo?
I believe you use the Blue revised actuator...
This make me confusing to buy or not to buy this turbo.
Some say good but some said not.
yep! mine was blue. i had less power then with OEM ported turbo, same tuner..
it was laggy, i also had problems with ALOT! of surging about 5000rpm, and i did NOT have any power at low rpm!
6th speed in about 90KM/T i had to go down to 5th...
With oem turbo i took me about 2sec before i had full boost and car started climbing up
Old May 4, 2014, 03:28 PM
  #56
veilside05's Avatar
HKS GTII brand new about 3k plus SGD in Singapore.
You can check out the Singapore Evolution forum as this turbo will comes out in the WTS section occassionally. My friend just bought one used at 1.2k SGD.
Old May 5, 2014, 06:05 AM
  #57
superkizuna's Avatar
I have an Injen intake. I can get a pic for you after class today.
Old May 5, 2014, 06:07 AM
  #58
I think you had some serious problems with your setup. What you are describing is a jacked up setup. And tell me how this 20g turbo makes the same exact power as an OEM turbo.
Old May 5, 2014, 05:44 PM
  #59
pangyau's Avatar
yungchian.chen,
What type of cam pulley are you using to pair with Greddy Easy cam? Stock?
I also tuning the ride to run on RON95.
If you want to let go your turbo. Please let me know.
veilside05,
Currency exchange not much favorable to buy stuff in SG at the moment
I've been to SG website... but still no luck.
What kind of setup/Hybrid you made on your TD05-20G turbo? Billet or convert to Ball Bearing?
Old May 9, 2014, 12:10 PM
  #60
TJung's Avatar
Hello, its me again. Ive changed my stock rubber intake tube for metal one and the spool isn't any better. The sound is impressive, but i feel like the turbo spool is even worse. Is it possible? Maybe I should start with changing licp? Or leave it alone :-)
Quick Reply: Tomei arms m7960
