MAF removal?
MAF removal?
what kind of gains would I expect if I got this kit? Will it increase hsp or is this mod more for conveniene and just removing it. Im looking to get a tune, but Im wondering if I should hold off on it untill get this installed? or I can get this kit later done the road. Thatnks for your time in advance
The Speed Density Kit eliminates the MAF(Mass Air Flow Sensor)
IMO, i would absolutely do it. i feel the car drives WAY better on speed density, plus you will gain power from removing the MAF because its a restriction.
i believe even on a stock turbo, by going to speed density youll see 5-10whp increase. of course the bigger the turbo the more the gains..
ALright thanx for the info, jus wish I would of known that before I bought a 4" to 3.25" reducer coupler....lol theyre not cheap since no one really makes that size
S.d is amazing !!The only problem is that it's takes time to dial it in perfect so you might have to visit your tuner a couple of times to make it perfect..The car will ,spool faster,drive smoother.keep your afr more accurate till redline,make more power ,and will not buck anymore from bigger cams or vta bovs..
The 4 bar map sensor I bought from map for map performance $85 the pigtail I got from the junkyard off a 1999 suburban and he only charged me $5 bucks sensor from napa for$ 15 and the bung a muffler shop for $5 ..opps It was $110 found all in 30 min..
