What is the Estimated Torque & WHP for my Set-up???
Hi guys,
im just curios what is the estimated torque & whp for my new rebuilt set-up?
Engine Spe'c :
1) Walbro 255
2) FPR
3) 560cc Injectors
4) 600mm x 300mm x 70mm IC with 2.5" Pipings
5) JE 85.5mm pistons
6) BC I-beam rods
7) GSC S2 cams
8) Stock Evo 5 Td05hr turbo
9) Manifold with Turbosmart wastegate
10) Profec B Boost controller
11) PFC Ecu
A) High Boost 1.4 Bar = ???
B) Low Boost 1.2 Bar = ???
Thanks
Engine Spe'c :
1) Walbro 255
2) FPR
3) 560cc Injectors
6) BC I-beam rods
7) GSC S2 cams
11) PFC Ecu
Thanks
im running normal ron 97 pump gas and what is the max boost for a stock TD05hr 16g Evo 5 turbo can go?
As i dont want to max the turbo...
Thanks
jameswwt
43
May 4, 2011 06:25 AM
