RnR Turbo Kits released
Old Dec 1, 2003 | 12:55 PM
superz's Avatar
I need RNR to answer this question because only they know which GT35 they are using as there are a handfull of versions.
Old Dec 1, 2003 | 01:00 PM
sir lurks alot's Avatar
Originally posted by superz
RNR, could you please describe the difference between a GT35 and a GT35-R? I cant find any specs on this turbo. Thanks
I think the R is probably for reverse, as in the turbo's on our cars spin counter clockwise. Check out the sticky in the turbo forum.
Old Dec 1, 2003 | 01:14 PM
RnR Racing's Avatar
R is the dual ball bearing turbo.
We expect full boost to be around 4000rpm in the GT30R
Full boost in the GT35R is 4500-4700rpm.
The GT L2R Kit (GT30R) is going to be the perfect set up for a very very fast daily driver. The GT35R kit has a lot more potential, but at the cost of more lag.
Old Dec 1, 2003 | 01:26 PM
What do you guys recommend for engine management? Will a SAFC do it or do you need a stand-alone?
USP45's Avatar
If using pump gas, and ONLY pump gas, i.e. no 100 octane, no water/alcohol, no nos, is there a reason to run the 35 instead of the 30? From what I understand 540-550 crank or 430-460 whp is about all you can get on 93 octane pump. If the GT-30R will hit this mark on pump I do not see a reason to go with the GT-35R unless you are going to run one of the things above. Is this correct or not? I want to do one of the kits, I just want to make sure that I pick the correct one out of what is offered. How long until you guys can post up graphs comparing the 30 to the 35, hell for that matter graphs of all five kits including the t3/t4 combo's? I want the spool characteristics of the BB center section, but I am sure that people would like to see all of them. Sorry for all of the questions, but I am pretty sure that I am not the only one with these same questions.
Old Dec 1, 2003 | 02:02 PM
superz's Avatar
Well said. My point exactly! If im planning on an all-out turbo for pump gas, then wouldn't the GT30 be the best choice? It would be cheaper and also faster as it wouldn't matter if the GT35 CAN produce more power if 93 octane is what calls the shots. To me I can't see why install a turbo that lags and can only work optimally on race fuel.
Old Dec 1, 2003 | 02:05 PM
MrBubbler's Avatar
aye this is a good question i would like to achive 500+ whp plus on race fuel but also have enough power on pump gas to beat anything on the road... gh35 r or gt30r???
Old Dec 1, 2003 | 02:11 PM
ItsStockOfficer's Avatar
There is a point of diminishing returns for pump gas turbos. In all honesty the GT30R is going to be right on the line you may only want to cross if you plan on using race fuels relatively often. It will still make more power on pump, but it may only make 20-30 hp on pump where as it will make 80-100 more hp on race. So is 25 hp worth 500 rpms in lag, maybe not.....but is 80 hp worth it?
YES =)
Old Dec 1, 2003 | 02:43 PM
superz's Avatar
actually, the GT30R is capable of putting down at least 430whp , at least thats what I hear. Of course, on 93 octane. It is closely related in size to the HKSGT3037 so 430whp should be ok. The GT35 on the other hand can put out over 500whp and blow the doors off the GT30, but you'll need race fuel. Any experts with experience with these turbos please correct me of im mistaken.
Old Dec 1, 2003 | 11:44 PM
superz's Avatar
its extremely confusing once you look into the GT family of turbos. There are GT30 turbos that use a GT40 compressor, and there are GT35 turbos that use a GT35 compressor. In other words we have a wide variety of mixes available. From what I understand all GT series turbos are dual-ball bearing design. So I still dont understand what a GT35 -R is. What is the R spec indicate? For racing? If so , what makes them different. I expect all these questions be answered by the kit providers as they are very important when you need to choose between one or another kit. Thanks.
Old Dec 2, 2003 | 06:24 AM
94AWDcoupe's Avatar
You shouldn't be looking at the gt turbos if they dont have an r at the end. The r stands for ball-bearing center.
There is only one gt35r. It uses a gt40 compressor wheel and gt35r turbine wheel. There are no wheel choices with this turbo. It is very hard to get your hands on one of these turbos.
Ther are many gt30r turbos. lots of wheel choices. Two different turbine sizes. A slew of compressor wheel choices. But anly a few have been shown to work well. Be looking here for a god turbo choice for your EVO8. The 35r is too laggy.
Old Dec 2, 2003 | 07:20 AM
superz's Avatar
Actually you're mistaking. There are a handfull of GT35R versions. I've seen it on various websites. For examplehttp://www.speedstate.com/Merchant2/merchant.mv?Screen=PROD&Product_Code=ALL-FIN-FIKIT-GARGT35R&Category_Code=TOY-FIN-FIKIT&Store_Code=S-US
Old Dec 8, 2003 | 05:36 PM
evo84me's Avatar
Re: RnR Turbo Kits released
Originally posted by RnR Racing
Well guys as some of you already know we have released our turbo kits for sale now. We had several people already on the waiting list and those kits will be shipping out this week. We will be taking orders starting Monday morning. I will give some of the levels we are doing so you can get an idea on pricing.
Pics are not jet hot coated yet, but they will before shipping.
Features:
GT Dual Ball Bearing Turbo
321 SS cast 8 gauge manifold
Jet hot coated manifold
3" SS 02 housing(bolts up to current downpipe)
Tail 38mm Wastgate
SS Dump Tube
AN fittings
SS oil lines
coolant lines
SS bolts, nuts, washers, etc
SS gaskets
hose connectors
everything need to bolt right up to your car
GT L2R (GT30R Turbo) $3100
500WHP
GT L3R (GT35R Turbo) $3600
650WHP
We will also be offering standard bearing turbos. There will be 3 levels we offer, but we can do a special set up fi you need it.
Features:
T3/T40E standard bearing Turbo
Jet Hot coated manifold
Tail 38mm Wastgate
SS Dump Tube
AN fittings
SS oil lines
coolant lines
SS gaskets
hose connectors
RnR L1R (50 trim) $2495
450WHP
RnR L2R (60 trim) $2495
550WHP
RnR L3R(56 trim, SC61) $2695
650WHP
This is all final pricing. We have quoted several people prices, but these will be the retail pricing. We have severla people who have already ordered the kits for a lot more, but we are selling them for these prices so you luck out on these kits.
We are throughly tested these turbos on the 4G63 and have found great results with all these combos. So you can rest assured you are buying very well proen set up that is going to make a lot of reliable power.
Let me know if you have any other questions, Ryan
is this price shipped
Old Dec 8, 2003 | 06:05 PM
RnR Racing's Avatar
Add $45 for shipping.
Our GT35R kit defintely isn't to laggy for the EVO. It actually works out pretty well.
I am very happy with it on my daily driver.
Old Dec 8, 2003 | 06:21 PM
nonmature's Avatar
I'm pretty sure that this would be more for those who go to the track every weekend who have 2 alternate fuel and ignition maps one for 91-93 and one for whatever race fuel they would be running i.e. 100-116...
-non
Quick Reply: RnR Turbo Kits released
