5 spd back to 6 spd?
stick with the 5 speed.. the 6 speed tranny is really weak! i regret buying an mr. but is great to know that you'll have 6 speeds and if you use the car as daily driving.. although it doesnt make much of a difference...
To answer your OP:
You need
-The gearbox (1500ish used)
-Shifter base assembly (300$ new)
-Shifter cables (100$ new)
-Trans mount (70$ish new)
-Trans wiring harness (reverse & VSS) (70$ new)
-Center console plate (100$ new)
-Clutch (good to change while its out. Most places sell a different version for the 6spd, so the previous post may be inaccurate).
That's pretty much it. If you need any like new 6spd parts give me a PM. I did the conversion to a 5spd and have all my left over parts.
You need
To answer your OP:
You need
-Trans wiring harness (reverse speed & VSS) (70$ new)
You need
cool bro if i decide to go 6 spd ill deff. hit u up
kambodianboi
May 11, 2010 07:59 AM
Steve@NoLimitmotors
Dec 23, 2006 07:33 PM
