White smoke
First of all, you need to positively identify the smoke. It's easy to differentiate oil from coolant from gasoline.
If it were valve seals, you'd typically see a good puff of oil smoke from the exhaust if you let the car sit overnight, then start it.
A leakdown test exposes far more issues than does a compression test, so despite the fact that one cylinder is down 10%, don't expect that a compression test will necessarily expose the condition.
out of the 3 ppl who looked at my car so far including myself 2 out of 3 said the smoke is white...and it is a huge puff of smoke everytime...ppl move from behind me on the road because there is that much smoke.
Well, unless there is someone in the trunk who smokes a blunt and exhales every time you let off the pedal, I'd say you probably have a HG issue. First, identify the smoke, then try a leakdown test. The number of ways a squirt of coolant can get into the engine upon vacuum are finite.
i'm going to have to get my hands on a leak down tester tomorrow and see what i can come up with......sighs......def not trying spend alot of money on fixing this problem
ok, it still sounds like head gasket then. whatever it is, when you find out let us know. So if it happens to someone else it can save them the headache of trouble shooting it.
i found this on a honda forum...
does it happen on deceleration, acceleration or just when you take it our of gear?
Generally blue smoke under acceleration is worn rings, smoke under deceleration (let up on the gas while in gear) is valve guides. and smoke when you take i out of gear just means nothing good...
blue smoke = oil
white smoke = coolant
black smoke = fuel Read more at http://www.honda-tech.com/showthread...ktrack=kcplink
i'm gonna go ahead and say my valve guides are leaking like i stated in an earlier posts...still trippin me out the because i went over 600miles and the oil still on the full mark
blue smoke = oil
Re: bluish white smoke from exhaust (SIK IN DA HED)
Don't forget to check your oil return line. If it has become kinked for some reason the oil won't drain properly into the pan. Then it'll back up in the turbo, eventually leaking out the seals into the exhaust housing, causing bluish white smoke to exit the tailpipe.
something else for me to check in the morning
