White smoke
White smoke
Ok...all of a sudden my car is blowing out some nasty smelling white smoke out of the exhaust everytime i get out of the throttle...doesnt do it at idle and doesnt smoke while my foot is on it...i did the obvious checks.....no coolant leaks or contamination...oil level is still full...i'm trying to find someone right now with a compression tester so i can test it for ****s and giggles but as of now i do not know why it is doing that....any ideas or suggestions....and please dont say search....because I did and didnt find anything with good information.
mods
1000cc injectors
255lph fuel pump
megan tbe
invidia o2 housing
megan manifold
fp black
injen ic pipes
agp fmic
bc 272s
exedy twin disk
shep trans
mbc
steel clutch line
mods
1000cc injectors
255lph fuel pump
megan tbe
invidia o2 housing
megan manifold
fp black
injen ic pipes
agp fmic
bc 272s
exedy twin disk
shep trans
mbc
steel clutch line
i do not have a wide band to tell you the afr's but its not only under wot...anything about 5lbs i would say and my girl is smoking...def doesnt smell like she is running rich it just smells like ****
yea the compression test will be done tomorrow afternoon that is the earliest i can get my hands on a compression tester...but i was thinking head gasket also but there is no coolant loss at all....zip zero nada
Ok...just finished the compression test and this is what the results are...
Stock Compression pressure should be around 145psi
and my values were
152psi
134psi
153psi
146psi
honestly i think my rings are perfectly fine...even the one cylinder with 134psi that to me should still be good seeing that its a 10psi drop.....the oil level is still full.....the coolant level is still full and there is no oil sheen or contamination what so ever.......i've filled up at 3 different gas stations and still the same thing.......it blows out the smoke on deceleration which would lead me to believe its my valve seals but my oil is still full....i did a oil change and drove over 600miles and its still at the full level........
and my values were
152psi
134psi
153psi
146psi
