Post your Synapse DV config and results
#451
Just installed mine on my car. Pull Mode with A hooked up to vacuum. When I'm slow cruising when I push in the clutch to shift it makes a noise sounds almost like a rattlesnake. Also on half throttle or so pull around 10psi it flutters like crazy.
#452
I haven't had a chance to read the entire thread yet but let's see if anyone can help me out here. I bought a low mileage DV that came with A+B hooked up. I installed it as-is in the oem-style push mode and it works fine but if I'm only in partial throttle with some boost it seems like the DV is constantly open. Reason being I hear a constant "woosh" noise similar to what you hear when you let off completely but for the duration of the time I'm in partial throttle. I also attempted to tighten the preload and it was only about 1/4 to a 1/3 turn before it became very snug (I stopped trying to tighten it for fear of breaking something), should I keep it like this or loosen it all the way or something in between?
Thanks guys!
Thanks guys!
Go through tuning the valve, that is going to be your best bet, different ports different preloads etc. No body is going to tell you want you need, there are numerous suggestions throughout this thread for adjustments which worked for specific people and their setups.
I see, I would also think its lubrication from the valve etc....
#453
Finally got around to installing my softer Mil spec spring in my DV. I decided to put it back to port A, Pull mode, and no preload and it works flawless. I couldn't run port A before as the flutter was in every gear and with almost every throttle lift. Glad I finally put it in.
#455
Honestly, no disrespect to Mil-spec, but Synapse should have changed their spring by now.......
#456
i have just installed the synapse dv i received from no limit motorsports. i initially installed it as Pull and port A to vac source and B venting. it idled fine with no issues but whenever i revved the motor it would flutter on the decel. sounded like somethig from fast and furious
while checking out the rest of the contents that came in the box i noticed that there was an additional spring included in the box. this spring is softer than what was installed from synapse. so i switched the spring and changed the orientation from pull to push and connected port B to Vaccum and left A to vent to atmosphere. the car started and idled fine, this time after revving the motor no flutter was heard, i took it out to run some errands and it felt smoother and i didnt hear any surging or fluttering but i had to take it easy since it was raining pretty good today.
i did notice that it felt like it lacked alittle response but i'm not too sure how to explain it but i added a turn of preload just to see. i'll be driving it tomorrow morning and i'll see how it acts then. i also up'd the size of the valve cover vent hole to 5/8" and added catch cans to the vent system. so i'm sure that will affect of the cars drives now too.
heres the pic of it installed
#457
Went for a drive this morning. I was actually able to hear and pay attention this time since it wasn't pouring. I have it as Push port b, A venting and one turn of preload.
I noticed under partial throttle while the turbo is building boost from vac to about 5-10 psi it sounds different. Wasn't sure if the DV is opening and letting air out. This DV is definitely louder than stock lol. Boost seemed to come on quick and while cruising in 5th doing about 60mph I have it a little more throttle to induce boost pressure and to see if it would flutter didn't realize that it climbed to 80 pretty quick.
Between this and upsizing the vent hole on the valve cover the engine sounds different and feels smoother.
I'll still play with it and see what comes up.
#458
Excellent thanks for sharing. I am getting ready to go SD this weekend and was wondering how to setup.
#459
so i have been playing with the configuration of my DV. i have asked CBRD what they recommended and of course it was Pull mode single port. so i changed my to Pull mode and i had it on Port B to Vac and A venting. i noticed that it seemed to spool quickly but in 5th gear with partial throttle it pushed 20psi (according to my gauge) but it starting fluttering. so i changed the ports A to vac and B venting and now it seems to not produce quite as much boost. example in 5th gear partial throttle it made about 15psi but with no flutter.
so far idle is awesome, no stalling, afr seems more consistent and stable compared to before and the car ridesand feels smooth. i'm just trying to figure out what is normal for my setup and im not quite sure.
my current configuration is Pull Mode port A to vacuum and Port B venting with the softer synapse spring. builds boost quickly but it seems to be a touch slower and produces less boost than with the ports reversed
here is the pics of the install
i actually shortened the vacuum hose going to the DV after the snapped the pic.
what do you guys think?
#460
My setup is still working great for me...pull mode, running port B only with port A VTA...In regards to the flutter I had some in higher gears with the stock spring from Synapse. Once I picked up the spring, from Aby @ Milspec, I don't think I have had any flutter, maybe once. Also, I have yet to touch the preload at all.
#463
Was running Push, Port B. Really nice response, great driving, only downside was it fluttered a bit on decel sometimes after mild-moderate throttle.
So I installed Mil.Spec's softer spring last night. Now it drives just as well as the Evo 9 OEM BOV! No flutter etc. However, 90% of the awesome sound is gone, it's SUPER quiet now. :\ I tried it with mild preload... drove really good, then I preloaded the hell out of it, now I need to back off, or maybe try it with no preload as it seems to require a bit more throttle at cruise to maintain speed (more resistance?).
I think I stripped the preload nut though LOL so I'll have to tear it off.
So far though, the softer spring resolves all my issues. The only downside is the weak sound. Any way to recover some of that? I don't want to run it as a Pull VTA setup until I switch to Speed Denisty.
#464
Sorry, cant help you
#465
