What is the consequence for not Breaking In enough?
Hi,
i just wonder what will be the consequence by tuning the car on dyno for not breaking in enough mileage?
Currently i have clock about 1,000km and service twice.
Can i send my ride for dyno tune? As ive drive my ride daily.
Thanks
Thanks
Follow me down the dark path! Lol! Here ya go!
http://www.mototuneusa.com/break_in_secrets.htm
+1^ a friend of mine with a supra mkiv had his engine built and went against the grain and did a slow breakin with a way rich breakin map to the point that fuel was in the oil pan which is to my knowledge cylinder washout! Then he start burning oil. I guess the rings didn't seat right.
Any improperly broken in motor will experience heavy blow by, low compression which both result in a loss of power.
^^ The bore of the pistons shouldn't change the compression numbers, only the CR of the pistons will.
Boost will not seat rings either, vacuum is what seats rings. don't boost the **** out of a new motor, but don't baby it either, do vacuum pulls for the first ~20 miles and you are good to go, then get the thing tuned. Best way to do the vacuum pulls is on the dyno though.
