Boost leak !!
Boost leak !!
so a week after i had my car built (fpred evo9 440whp)
i started to notice my car isnt boosting to 25psi its hittin
16psi lmao, so my tuner told me it was the thorttle body
shaft seals
i bought the mil spec shaft seals wit a new gasket from
STM and shud be expecting them today in the mail
wat my quesiton was is .. is it diffucult to change the shaft
seals on the throttle body ??
how long would it usually take ??
bc i didnt really get to enjoy the car bc of the boost leak
any help would be great !!
thanks,
shaft seals
thanks,
boost leak test was done and its leaking out the throttle body the shaft seals r done
i dont have check engine on what i do have on is the brake light and battery light which is strange since i changed ot battery and did my 60k maintnence as well
all clamps r secure and tight and all vacume lines r good and hoses
i have a hallman pro x boost controller
i literally just finished my car
and im so pissed about this bc the throttle body seals rent supposed to make the leak go down by almost 10 psi !!!
i need help loll
i need help loll
Emery and the STM group are great bunch of guys and gal(s) and know their stuff so feel confident in taking it there for resolution. If you're trying to do it on your own and diagnosing it...it all depends on how far gone the shaft seals are. Once you replace them you can do another boost leak test but it does sound like wastegate pressure which means something could be connected incorrectly, generally a vacuum line issue. Are you sure your boost controller vacuum lines aren't hooked up reversed?
If your battery and brake lights are on you need to check electrical connections around the battery and alternator. That's a tell tale sign your alternator is going out and you could be running the car off battery power. Check voltage on battery, start car, disconnect negative terminal while the car is running, if it dies your alternator is dead, if it runs then it's probably your battery.
so just dropped off the car to the mechanic to get my throttle body shaft seals done and my boost leak checked and i found out why my brake light and battery light are on as well
when i brought the car for my build a few months ago the alternator was getting ****ty and i had a new battery in the car and the alternator ended up being needed to be replaced so when i changed the alternator i recharged the battery to jump the car and everything seemed fine and it seemed to hold the power well
then today when i popped the hood at the shop right before they were about to work on it .. battery acid was leaking out the battery .. so im picking up the car tomorrow with a BRAND NEW BATTERY and the shaft seals and boost leak fixed and the engine bay cleaned out and hopefully this wont happen again :/
anyone else have this issue !?
then today when i popped the hood at the shop right before they were about to work on it .. battery acid was leaking out the battery .. so m picking up the car tomorrow with a BRAND NEW BATTERY and the shaft seals and boost leak fixed and the engine bay cleaned out and hopefully this wont happen again :/
Which shop did you go to?????..If I was you I would take consideration in going to emery at stm your car would be nasty!!!!Emery is a genius when it comes to stock block's. He's the stock block king in the evo world and brian sends me candy when I always order parts from them . As far as stm goes emery always give's me helpful advise and brian sends me candy when I order parts from them..
