stupid wastegate question....
Those external gates are for other turbo's other than "stock frame", unless you have the MAP system. External WG give more flow and more precise control over boost to an extent. You can also upgrade your internal gate if you want to push more boost on a stock frame turbo.
To the OP: No! An External gate is not worth it on a stock turbo/stock exhaust manifold setup. Just forget about it and go back to thinking about other possible power mods.
sparky To the OP: No! An External gate is not worth it on a stock turbo/stock exhaust manifold setup. Just forget about it and go back to thinking about other possible power mods.
thank youu!!!
thank youu!!!
[WTB] Wastegate Actuator
lancerrally45
May 20, 2016 06:16 AM
[WTB] evo 8 turbo + wastegate
thenatureboyjs
Feb 15, 2015 10:41 PM
