winter Project ''project 9'' by Evodan2004.
#136
evodan, what did them coil-overs setup run you? I'm looking to get a set of coil-overs and just can't make my mind up. Looking to save some weight, handle better (I am on stock struts and lower springs unfortunately), and a good all around setup but the car is mainly street driven anymore. Maybe drag more in the future just not for a little while...
#137
new rear control arms arrived today. i seem to have more parts on my floor then i do going on the car. this means i need to get moving. but i just took them out of the box so it is now break time.
#144
front and rear coilovers, sway bars, control arms are in. i have nothing left to do until my parts start coming in. i am waiting on my manifold, turbine, DP from swain tech to come back. thats about 2 weeks. i have exhaust wrap i will put on the DP and i got to contact buschur for the turbine blanket. the TRE rear should be here soon. i got mine out ready for the new one. he had one in stock so it should not be to long. the 3.5 aluminum DP back exhaust is in the works and will be here soon as well. for now i can just sit back and wait until the parts get here or until i buy something because im bored. HAHA. anyone got any light weight options????
#149
this wont get me into the 9s but when i do run 9s and pop the hood ill at least look good too.
i stole this pic from RUNTHAT on the forum because i saw these a long time ago. i thought they stopped being made and he bought them and posted a pic. i was so excited i PM'ed rexpeed at like 2a.m. in the morning and he replied back. haha so i bought them on the spot and they came in the mail box today. i would take my own pic but 1. i dont want to 2. im drink as f^&k and 3. i just took his pic's and 3. im to damn lazy.
#150
TRE rear has arrived. here she is and a list of some of the stuff i had done
magnaflux inspection of differential carrier housing and bearing caps
magnaflux inspection of ring & pinion and spider gearset
new friction & drive plates (12 plate is standard)
shot peening of ring & pinion
shot peening of spider gearset
new pinion & carrier bearings
new shim kit for preload of both pinion shaft and carrier housing
adjustment of the spider gearset backlash
adjustment of ring & pinion for high torque applications
new pinion shaft and axles shaft oil seals
a heavy coat of satin black paint so it looks like new again
new fill plug
new drain plug
modified side sheaves & cross shaft
new carrier cap bolts
new rear cover bolts
new rear cover with oil sight glass
new TRE HD side cover
new fill plug
new drain plug
