Difference in the fp red
We'd need to fully analyze your specific case in detail so as to be able to best determine why in fact you're not experiencing any compressor surge "whatsoever", whereas others do with that same particular 64mm coldside configuration. Please post up detailed build and mod lists.
True. The modulation of the right foot, the amount of WG preload and the particular BOV/DV tightness all have an impact..... agreed buddy. I may be wrong, but I was just imagining that pflores210 just might have his WG set up with little or no additional preload and that his DV spring is on the light side. I agree that a sensitive throttle foot especially at part throttle openings is critical in part throttle situations.
I appreciate your input, EVO8LTW, and I am not being argumentative in the least. I just finished installing a 64mm Red on my Evo 8 and am really curious as to the driveability of this particular configuration. Thanks for your input and take care.
You just need an adapter coupling and then it will work. As long as you are using at least a 3" diameter intake, it shouldn't be a restriction until you get way up in power (over 500 whp).
It would be fine on a fp red setup at this point its all about what other mods octane used psi set to etc.
pls1968
Jul 13, 2020 02:16 PM
Bmurray
Oct 18, 2016 10:18 PM
[WTB] Fp stainless housing
Airflow86
Oct 26, 2014 12:23 AM
EvowagonIX
36
Nov 18, 2009 01:59 PM
