idle jumped up to 2500rpm ??
So my car was idleing fine, I hit the 2-step idle was fine after then I hit it again and after I let off the car was idleing at 2.5k. I got out checked the tb, it was closed. All vac lines are connected no rips. I shut the car off and started it again and it was idleing fine, hit the 2 step again same thing happened. I shut the car off go in my house come back start the car and the idle shoots up to 2.5krpm right away and wont come down. Any idea's? And theres no idle screw on my tb.
Im thinking its the iacv, thoughts?
no egr.
fuel cut based 2step
Ill check that. But I pulled the iacv and with the ignition on it doesnt do anything. Which from what I read up on iacv the motor should push out.
I was have some idle surge issues before where my idle would go up to 1500rpms from time to time.
Raceghost
25
Jan 27, 2017 03:20 PM
Raceghost
Jun 17, 2016 04:05 PM
