Wierd problem... I need your help!
Just saw this, this may also be a problem for you running the Red... Do the plugs first and go from there, eliminate one thing at a time starting with the cheapest solution which is plugs.
If you are running anything besides pump I would say your out of fuel pressure and may need to increase the it with an FPR and/or injectors or do a double pumper.
Ok guys thanks alot for your help and information. I tested the car again and this time the problem re-appeared. It seems to be kind of intermitent. Earlier today I did some runs ans nothing happened. It just kept pulling strong in 3rd. Then after a few hours I tested it again and it did it in all the 3 runs I did. When it was about to hit 6,000 it feels
like a fuel cut. As soon as it did it the AFR went to 12.7 and then immediately went back to normal and kept pulling. Also during the first few runs at the dyno, the car was acting normal. As soon as the timming and AFRs where smoothly tuned the car started showing the problem.
The car is being tuned with 93 pump gas. As for the plugs they were brand new denso plugs. However, as I said before, the car was having the same problem even before the new mods/tune. The problem was I thought it was tune related and that it would get fixed with the new tune .
Incidentally, is yours the original configuration of the Red with the stock sized 64mm compressor inlet, or the upgraded, ported antisurge housing?
Well, I'm pretty sure my tuner is not the problem. He is one of the best, if not the best in PR. It does feel like it cuts fuel, but I guess that there can be a hand full of problems that feel like that :/. Also the car wasn't stuttering between shifts. It only does it when it gets to about 6,000 rpms at WOT .
COP= Coil On Plug.
The evo runs two ignition coils split between the 4 cylinders. Most modern performance cars run what is called a coil on plug system. There's no plug wires and the coil packs are mounted directly on top of the plugs.
These guys have the best prices. They put together COP kits for the evo made out of currently available parts from other cars that are very reasonable. http://www.spoolinup.com/
COPs just give you a better spark and reliability. They're a must have for higher horsepower applications.
The way your problem is intermittent like you describe and the way it's persisted through different tunes and parts I would guess that it's a bad connection somewhere or a part is on it's way out but not gone totally yet, like a coil possibly.
Haven't talked to him. I've been really busy and I decided to take a break and forget about the car a couple of days, but I'll be calling him today and will tell him that. Thanks.
