Wierd problem... I need your help!
#31
http://www.youtube.com/watch?v=Nn5Cr6tSv0I
Heres the video of the actual issue. This is a 3rd gear pull. If I hit it from 2nd gear I can go all the way to 4th without any problems at all. It only does this from 3rd gear up. However, If I hit it from 2nd I'll go thru 3rd without the problem.
#34
^ glad you found out what it is. Your video was kind of hard to make things out but from the look of it your AFR should be a little lower shouldnt it.
Again, I couldnt see to well but it looked like you were hitting 12.7-12.9 when getting on it, if you were WOT then I think you should be in the low high 11's low 12's not around 12.7
