Misfiring Issue I Searched.
Old Dec 31, 2010, 06:04 PM
  #46
JYD
JYD's Avatar
im having almost exactly the same problem and have tried almost exactly the same things.
Old Jan 2, 2011, 12:38 AM
  #47
ZanarkO's Avatar
Originally Posted by RJSP
I think that JohnBradley is saying to bring the AFR to 11.5 and see if that helps, not to increase timing while you still have AFR of 10.xx
Hope this works out for you.
Naw I got it lol. anyways I dont really tune timing on the street you need a dyno for that. I dont tune timing for "how much timing can I ram in there before she knocks" you gotta tune for best TQ at a given load/rpm before the power increase is nill compared to how much timing your putting at it. Anyway the issue is still not fixed. And the weathers been really bad. Im going to go down to stock heat range plugs again BR7ES and gap them to .20 and see what happens.(again)
Old Jan 3, 2011, 07:38 PM
  #48
ZanarkO's Avatar
PRoblem fixed!! Kinda... Well I put a set of BR7ES in it gapped to .20 and put in my stock coilpacks (old ones) and no more breaking up issue. ALl the way up to 23 psi shes perfect however theres a little stutter sometimes in 3rd gear but thats more then likely the tune. So I put the BR8es back in and gapped to .20 but she breaks up. So with stock heat range plugs shes fine. Can someone please care to explain that to me? I honestly do not want to run the 7's hitting this type of load ANy suggestions on why the car breaks up only with the step colder plugs?
Old Mar 20, 2011, 05:50 PM
  #49
3gEclipseTurbo's Avatar
Bump, having the same problem. All ready tryed everything listed to try in this thread. Except the ngk 7's, im running 8's.
Old Mar 22, 2011, 07:33 AM
  #50
My03evo's Avatar
Just curious, the ones with the misfiring, are you guys running catch cans?
Old Mar 22, 2011, 07:46 AM
  #51
jameswwt's Avatar
Yes, to me...After gapped the plugs to 0.20 everything fine now...
Eisen7
11
Feb 28, 2020 12:42 PM
Evo47
Apr 10, 2016 01:00 PM
pinoy6969
Pacific Northwest
Jul 27, 2012 12:53 PM
CrackerJackToy
27
Apr 29, 2008 01:19 AM
Sgt Blamo
102
Dec 17, 2007 07:48 PM
Quick Reply: Misfiring Issue I Searched.
