I cant tell if my exhaust manifold has been ported
Sup yall,
To make a long story short I purchased a Buschur ported exhaust manifold from another board member. Before I installed it I decided to go a different direction and I purchased a tubular manifold. Well, I took the "oem" manifold off my car and it appears to be indentical with the Buschur ported manifold?!? I have them side by side and they look identical. I know the Buschur unit is legit. I'm more interested about the one that came off my car because Im going to sell it and Im sure it worh a little more if its ported.
Is there a way that I can tell with the naked eye?
I can measure the ports but I dont know the diameter of the ports on an oem manifold.
*Sidenote* I purchased my car used years ago, so its quite possible that the previous owner upgraded the exhaust manifold. Especially since the car has a 2005 turbo on it and its a 2003.
Do you have spare gaskets? Check inlets and outlets against both manifolds. A ported manifold should match the gaskets very well, where a non ported will show significant metal exposed through the gasket.
you could try and clean the manifold a little bit and see if it is smooth inside and if there is any scarring of the metal inside
usernameinuse
15
Jan 5, 2016 06:33 AM
CtSilver03Evo
25
Sep 28, 2011 07:31 AM
