Switched from Red to Black...
She's better off getting loans which you can help her pay for...it's a hedge against future uncertainly which could leave you without a girl and a car
ON TOPIC:
Mikey,
whenever I get around to finishing my MIL.SPEC build, I will try and see how close to your numbers I can get on 91 just for the fun of it
You guys gotta take Mikey's results with a grain of sand lol hes running a 2.4 with 10:1 or 10.5:1 compression, and its tuned on E85. Not a typical setup for the DD lol.
A more reasonable idea of what a good FPBlack build would be is another local guy who is running a 2.4 with I think 8.5:1 on 92oct. He made 520 or so whp at ~33psi, and it has SICK response. His black spools almost as fast as my stock IX turbo, but makes 150 more whp.
PS Mikey, you sell that car, and I swear to God that I will drive out to Whidbey, and beat your junk until it turns to mush.
If you are keeping the boost profile identical (from Red to Black) you really won't be gaining that much hp as you were operating the Red in its efficient range. That said, by the fact you have taken your IDC from 85% to 100% tells you that you are moving more air and needed more fuel, therefore you should be making more hp.
IMHO, given the same car, where the benefits are really seen is by turning up the boost ~10 hp / 1 psi (if in the efficient range). It has been documented before the Black should make 20 - 40 whp more than the Red (same car, same boost)....
OP you can PM me ill take a look at your tune/rom and give you my opinion if you want. I usually see around 70whp or more with red to black at the same boost.
Also ---------- my 2.3L @ 25psi made 590whp also (but omni 4 bar showed boost creep to 29psi)
I have lots of data over here of the perrin vs garrett core at certain boost levels.. the perrins fine until you attempt to run a certain boost level then you start really bottlenecking your setup bad. 2.8" endtank inlets arent exactly fp black turbo friendly.
keath how are you complaining about a powerband? your making 34-35psi by 4300-4400rpm on a 2.0L.. you can rev to 9500rpm and get the same powerband as us.. your car isnt exactly spooling the black slow.. is the response that much worse then the red? i never got a chance to notice the two back to back because i went from a red on a 2.0L to a black on a 2.3L. how much difference does the black feel vs the red in your honest opinion.. light to light, cruising, etc.. im curious?
WHO SAID I WAS COMPLAINING. lol
it is awesome power. only thing is i dont need to upgrade anything cuz black has too much power top end for the street...
i am extremly pleased with the tune and the price.... WTF???
I just dont need all that power for the streets of oklahoma LOL..
So get off my back ... complain??? that would be you complaining about my inj. and FMIC LOL
BTW i am only running 30 psi right now and still running at 510hp..
91 oct at 28psi made 450...
so just get the FMIC only so you can make more power with less boost that way the turbo last longer and remains in its efficiency range.
i think i'll have to get a new intake manifold and a larger TB.
@tscompusa - i'm running a haltech ecu. if you are familiar to it let me know
and i'll send you me complete map-file.
i attached my ignition map.
best regards,
Luke
best regards,
Luke
whats the 3d map look like of that graph? --- if its already base mapped and setup ok which i can see it is, then ya i can easily mess with it.. but do you have knock control with it setup?
bsbllfit7
24
Mar 5, 2016 07:58 AM
CVR Motorsports
EvoX 'For Sale' Interior Styling
312
Mar 10, 2010 08:18 PM
DynoFlash
116
Dec 8, 2004 11:00 AM
Jrod@Buschur
Apr 13, 2004 12:12 PM
