Forward Facing Stock Turbo Manifold??
#31
Even after that, you still don't know if it is going to operate correctly and cool just as well as the factory A/c does. Our A/C system just wasn't designed to run on a condenser that small. Trust me, I thought a million times about this before deciding to go "back black". Maybe if someone gets it to work properly, I might go back later in the future.
#32
I was going through the process of building a forward facing black- I see David is beating me to the punch with the red and I can't wait to see the results- as far as putting it together goes- If you already have a red or even a stock 9 turbo it is cheaper to get the turbo rebuilt by FP than buy a new 6262 or whatever- and the maniold/02/DP and lines would have to be changed either way. I was doing the FF stock frame to be different- to each there own. Although I have to admit I may go for something different now
#33
Correct me if I'm wrong but dont people go FF turbo set up's to spool quicker hence all the air going in drastically in to the turbo? Would that really be effective on a sock turbo since its so small and not lagy, I figured people did it cause theyre huge turbos.
#34
I have a question for anybody that is very knowledgable on the FF manifolds...i recently seen the precision 6262 turbo with the FF manifold and it looks dope cuz its right in the front and you can see it BUT what are the pros and cons of it being where it is?? like is rain or water a issue or like bugs flying in there or something...??
i would appreciate it if someone could help me out before i save up to purchase it! thanks
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
#35
1 Post
Running a FF on the street with no kind of filter is asking for it. Running the FF with a filter in torrential downpour without a cover of some kind is also asking for it.
#36
i would appreciate it if someone could help me out before i save up to purchase it! thanks![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
We sell a front facing kit or just the manifold Separtly
http://extremeturbosystems.com/cart/...Turbo-Kit.html
We do have customers who run our kits with a small KN filter. Good luck!
Thanks,
Michael
#37
#38
Try breathing thru a straw, and then take a regular breath, it's a lot harder to breath thru a straw, your turbo feels the same way, if you run an ample inlet (intake diameter) it makes it easier for your turbo to make boost (cooler, denser pre-intercooler air). Now ram the air into the turbo(forward facing), you are actually changing your turbo's pressure ratio differential, you could be putting close to 2psi maybe a little more from the ram air effect at 100+mph, on the inlet to the compressor, which translates into more power, and your turbo is not working as hard trying to suck in the air!
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
Dave's setup with the 2.3RPM and a FF Red should be an autocross MONSTER, the FF will just maximize the combo.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
#39
Our kit uses a LARGE custom built air filter and we can supply a block off plate for driving in crap weather.
My car has an HTA86 on it, not a red. We offer a 3/4 width radiator forth stock style turbos that if you are on SD you can turn the filter and turbo inlet ton the grille opening.
#40
I am building one...........for the Bad Bish actually.
The other option is the new product release I just put up in Vendor Announcements. It's our new forward facing inlet for the stock appearing turbos. Uses a 3/4 width radiator, new turbo inlet and filter. Check it out.
https://www.evolutionm.net/forums/ve...air-inlet.html
![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
XSilverJ
80
Jan 30, 2016 07:37 AM
fazevo5
Nov 28, 2015 12:57 PM
alex_s817
20
Apr 25, 2013 05:03 AM
