Forward Facing Stock Turbo Manifold??
I don't know if this has been asked before. But has any one made a Forward facing Stock turbo manifold yet? I know they would have to make a different down pipe to go with it. Also would have to run it with out the MAF ( ecu -stand alone or SD ). I wonder how this would perform. It would be good for FP and BBK turbos. If their is could someone post pictures or a link to a web site.
(Please don't bash me if this is a dumb question or idea.)
Why do you want a forward facing manifold? What are the benefits? Can someone please show me a dynosheet where a front facing manifold is compared to a stock location manifold with the same setup.
I am building one...........for the Bad Bish actually.
The other option is the new product release I just put up in Vendor Announcements. It's our new forward facing inlet for the stock appearing turbos. Uses a 3/4 width radiator, new turbo inlet and filter. Check it out.
https://www.evolutionm.net/forums/ve...air-inlet.html
Yes and no. Shearer was taking orders to make one for 1000 a pop. I think thats way overpriced but hey whatever. I thought about making and DID come up with a concept peace for mona lisa Version 2.0 but as stated above I dont see the point in FF manifold turbo on a street car period. to may things could happen not to mention the extra cost you will have to indur just to look cool. Custom A/C kit so you can keep that cool air then conversion to SD or aftermarket ECU then custom downpipe as well. Have to get smaller radiator to. By the time your done your right at the price of a t3 kit etc and the whole benefit of the stock frame turbo pricing point and still making power is thrown out the window. if your going that route might as well send your turbo to owens development and get a BB conversion to complete the transformation and again add more cost to this costly en devour
Not really worth all the coin involved unless you just want that custom look
I don't agree. There's not a turbo in T3 configuration that works as well as a Red does, not that I've ever seen. Most guys have the Red already so it's a matter of buying an 02 housing and header, maybe not even a downpipe depending on how the kit was built. No external gate required depending on how the kit is built. The cost isn't even remotely close based on those things.
There is no down side to a FF kit on the street. I never wanted A/C in the first place and is why I bought an RS to begin with. The FF kits work on the track at high speeds, absolutely no doubt about it.
I personally like the front facing kits. I don't see anything wrong with the bolt on turbochargers, but when you start sending them in to be modified from Journal Bearing to Ball Bearing and then upgrading the manifold, downpipe, o2 housing, wastegate actuator, lower pipe, oil lines and a custom intake because of the upgraded compressor cover, it does get spendy fast.
It can go both ways. We have built some crazy custom manifolds in the past. Twin gated external dump stock replacement for the FP turbo... etc. We could definitely build a front facing stock replacement if there was a demand though.
Thanks,
Michael
Thanks,
Michael
I am glad I started a good thread and some big named shops have chimed in.
I have seen some 6262 FF turbos out on the street. So why couldn't you do one for a stock housing one. You might have to reroute some of the lines that go to the turbo. But you would need to do that anyway to any FF turbo kit. Right?
Buschur-- Your kit with the new radiator is cool and all but I was thinking about how they do the kits for the bigger turbos but make one for the stock housing ones. Something along them lines.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
[QUOTEBuschur-- Your kit with the new radiator is cool and all but I was thinking about how they do the kits for the bigger turbos but make one for the stock housing ones. Something along them lines.[/QUOTE]
I don't get it. Maybe it is just me, but this sentence is confusing. Can you elaborate more please.
he is talking a complete kit like on this car below
manny
lines
radiator
o2 housing
downpipe
turbo
Custom A/c kit or not
http://www.youtube.com/watch?v=DZAGUut1gIY
the issue is not making a complete kit thats no problem the issue is how much it will cost to get all the required peaces and Custom A/C kit or no a/c does not matter once its all said and done you could have gone t3 route thats all thats being said. I guess its not cost effective really and not like your going to gain a Ton of power or something.
manny
lines
radiator
o2 housing
downpipe
turbo
http://www.youtube.com/watch?v=DZAGUut1gIY[/QUOTE]
Yes this is what I meant. Thank you for clearing that up for me.
