Rolling forward in neutral??
For the basics i have a Exedy Twin disc clutch and stock 6 speed trans.
My problem is while the car is in neutral and my foot is off of the clutch pedal the car will roll forward!? Everything frees up as normal when i press the clutch pedal in. Please help, ive searched and searched for answers and have had no luck.
In neutral with the clutch out, the input shaft inside the transmission is spinning. This shaft has lots of gears on it.
If the ambient temperature is low enough and depending on what you are using as transmission gear oil, the oil being stirred by the input shaft, when very cold and stiff, can possess enough power to move the output shaft and hence the car. This is fluid coupling, the same as in an automatic transmission.
Same thing happened to me. Made a thread about it and people said its the oil, still have to change it >.>
https://www.evolutionm.net/forums/ev...old-start.html
I don't see this as a problem, only a curiosity. Normally, you start the car with the clutch down, put it in gear and drive off. If you are wanting to warm the car, the parking brake should be engaged. So, no need for swapping tranny oil.
Agreed. I went out to check through all possibilities, thanks everyone it is definitely the oil.
Stinkapuss
Jan 13, 2004 04:37 PM
