car wont start :/
car wont start :/
i have a 2005 evo 8.
as i was driving, my car just cut out, i pressed the gas and no response, as soon as i slowed down to about 20 it completely shut off.
as i pulled over and tried to start it up, it started but as soon as i tried to give her some gas it died again.
when i towed it home, i was told to change my fuel pump.. i changed it and it still wont start at all.
i took a fuel rail and put it to a bottle, when i crank it pumps gas... and if i add fuel starter while trying to start, it starts up for about 2 seconds, but dies right after.
has anyone had this problem before?
any help would be appreciated.
but now it doesnt start at all. unless i add starting fluid, which has the engine run about 5 seconds till it dies.
i checked all the pipes, that was the first thing i did.
i heard it might be the injectors.
air fuel and spark man.
air - check your piping, check your timing, check your compression
fuel - check gas level, check fuel pressure
spark - check ignition
starter fluid, really? what do people use that for? help start the fire?
well i had an electrician look at it, and he told me that the new fuel pump i got was not giving enough fuel.
if we rev the car to about 3k RPMs it will start, and if we keep it at 3k rpm it runs..
so i bought a used fuel pump, but at least its OEM and i know the seller.
hopefully this works.
